YetAnotherForum.NET Help
hz dude Offline
#1 Posted : Wednesday, 12 September 2007 7:34:18 AM(UTC)
hz dude
a mates VB sle has 308 th400 and 2.60 diff,
not enough take off for him thinking of changing
to a 3.08 out of fuel injected VK 6cyl .
Its a daily driver around town but what
rev range might it have on the highway and is it
ok to use this diff I know that they run V8
running gear to deal with the fuel injection but
still will it handle it .
thanx dudes
its beer o'clock
Munromad2004 Offline
#2 Posted : Wednesday, 12 September 2007 7:50:31 AM(UTC)
Munromad2004
3.08 will be fine. It was probably the most popular ratio in V8 HQ-HZs.
I guess around 3000 rpm at 100km/hr would be about right.
However I have no idea about the differences in VB V8 diffs and VK 6cyl diffs.
#3 Posted : Wednesday, 12 September 2007 7:50:31 AM(UTC)
Munromad2004
3.08 will be fine. It was probably the most popular ratio in V8 HQ-HZ's.
adam PERTH Offline
#4 Posted : Wednesday, 12 September 2007 9:55:49 AM(UTC)
adam PERTH
VB 5.0 diff = 10 Bolt sailsbury
VK 6 Cyl diff = 8 Bolt (round) sailbury (Banjo internals) not as strong, but cheap and pleantiful if it lets go.
A1 Bogan.
basketcasebear Offline
#5 Posted : Wednesday, 12 September 2007 10:21:04 AM(UTC)
basketcasebear
hey hz dude,
what revs are you doin with the 2.76 diff, at 100k,s???
ptpro
DOH!!!
adam PERTH Offline
#6 Posted : Wednesday, 12 September 2007 10:22:48 AM(UTC)
adam PERTH
normally around 2700 with 14"
A1 Bogan.
#7 Posted : Wednesday, 12 September 2007 10:30:56 AM(UTC)
basketcasebear
i think i want one of them ratio,s in my new diff,
thanks again adam
ptpro
DOH!!!
hz dude Offline
#8 Posted : Wednesday, 12 September 2007 7:37:27 PM(UTC)
hz dude
adam perth I have 2 VK fuel injected diffs both are 10 bolt
oval disk brake. Ive never seen 8 bolt in a injeceted 6cly.
always been 10 bolt in my case maybe Im just lucky.
as for the rev range its a 2.60 and it hasn't made it to
the highway yet but m
Edited by user Wednesday, 12 September 2007 7:41:51 PM(UTC)  | Reason: Not specified
hz dude Offline
#9 Posted : Wednesday, 12 September 2007 7:37:27 PM(UTC)
hz dude
as for the rev range its a 2.60 and it hasnt made it to
the highway yet but my
#10 Posted : Thursday, 13 September 2007 7:34:56 AM(UTC)
i want to put a vk commodore gearbox and diff in my hr. I want 3.08 diff i do a fair bit of highway use and i want to get my rev range down at 100
musksell Offline
#11 Posted : Thursday, 13 September 2007 8:19:02 AM(UTC)
musksell
If the tyres were 14 inch 3.55 about 3000rpm 3.08 should be about 2600rpm
2.78 about 2300rpm 2.60 about 1950 rpm ......all at 100k
alot of rev counter arent super accurate....the dyno is more so....
musksell Offline
#12 Posted : Thursday, 13 September 2007 8:19:02 AM(UTC)
musksell
alot of rev counter aren't super accurate....the dyno is more so....
#13 Posted : Thursday, 13 September 2007 10:43:32 AM(UTC)
The up/down side of 2.60 diff gears are that you need good power to drive them to high speeds. A HX wgn std 202 auto a mate owned did a max speed of 130 kmh with 3.08 diff ratio and could only manage 110 kmh with a 2.78 diff and the hills killed it. It ju
Rados Offline
#14 Posted : Friday, 14 September 2007 6:58:37 AM(UTC)
Rados
dose anyone have a 3.08 banjo 4 sale
Guest (5)
This page was generated in 0.110 seconds.
