#1 Posted : Tuesday, 23 October 2007 9:19:05 PM(UTC)
has anyone seen this coversion done ?? If so is it a big job ? anything i need too be cautious of
JBM Offline
#2 Posted : Tuesday, 23 October 2007 10:10:24 PM(UTC)
JBM
I have heard of a 350 in a VK so would similar for a 327, but the question is why? If you have that much spare cash to do an oddball conversion you could give some to me and just stroke a 308.
James
#3 Posted : Tuesday, 23 October 2007 10:17:27 PM(UTC)
I agree. Sump is your problem. Easier and cheaper to stroke a 308 to 350, or fit a GenIII crate motor with a carby.
#4 Posted : Wednesday, 24 October 2007 12:12:09 AM(UTC)
dont really under stand the reply from JBM but any how the sump is the problem i guess ? cheers Byron for your response and i will be at the van this week so i will give ya a buzz about the saginaw
#5 Posted : Wednesday, 24 October 2007 12:39:34 AM(UTC)
Hi Guys.
It's not so much the sump itself that's the problem, it's the location of the oil pump inside the sump.
I've seen a guy make a sump to suit SBC into Commodore, but he forgot about the oil pump. You could go to a dry sump set-up, but then th
#6 Posted : Wednesday, 24 October 2007 12:39:34 AM(UTC)
Hi Guys.
Its not so much the sump itself thats the problem, its the location of the oil pump inside the sump.
Ive seen a guy make a sump to suit SBC into Commodore, but he forgot about the oil pump. You could go to a dry sump set-up, but then things
#7 Posted : Wednesday, 24 October 2007 10:41:42 PM(UTC)
Cheers doc for that much appreciated
