trubluhq Offline
#1 Posted : Monday, 29 October 2007 8:33:39 AM(UTC)
trubluhq
Hi folks,
I have the 253 out of the Prem. What a HUGE F*&%$#@ hole is left !!
Would now be the BEST time to remove, clean and repaint those huge inner guards ?
Or can they be done with the back engine in ? I have no idea on this one...never done it. Too many bolts from memory.
Advice welcome. Cheers John
HQforme Offline
#2 Posted : Monday, 29 October 2007 10:28:09 AM(UTC)
HQforme
Traditionally its done before the motor goes in. Its a hassle, but to make sure it works, you trial fit the motor (just sit it in place with nothing joined back up) to make sure theres no major headaches that would arrive when your newly painted guards ar
"Silly modern cars"
HQforme Offline
#3 Posted : Monday, 29 October 2007 10:28:09 AM(UTC)
HQforme
Traditionally it's done before the motor goes in. It's a hassle, but to make sure it works, you trial fit the motor (just sit it in place with nothing joined back up) to make sure there's no major headaches that would arrive when your newly painted guards
"Silly modern cars"
pdtphil Offline
#4 Posted : Monday, 29 October 2007 6:43:43 PM(UTC)
pdtphil
Gday John, I have just done a 308 rebuild in my van. I took the entire front end off. Its just 8 bolts possibly 10. 2 to the chassis at the radiator, 1 each side of the windscreen cowl, 2 each side bottom of guard to body and 2 or 3 each side inside the
"If in doubt, Power out"
pdtphil Offline
#5 Posted : Monday, 29 October 2007 6:43:43 PM(UTC)
pdtphil
G'day John, I have just done a 308 rebuild in my van. I took the entire front end off. It's just 8 bolts possibly 10. 2 to the chassis at the radiator, 1 each side of the windscreen cowl, 2 each side bottom of guard to body and 2 or 3 each side inside t
trubluhq Offline
#6 Posted : Tuesday, 30 October 2007 8:19:22 AM(UTC)
trubluhq
Thanks guys...if the kids arent around I may give it a shot..but I am running out of room in my garage...LOL...full of car and car bits !!
Cheers john
Guest (5)
