#1 Posted : Monday, 12 November 2007 10:08:46 PM(UTC)
81237QJ303838
10/71-BHQ16058M
Mod-HQ81237 LS Sports V8 3sp 3.08 diff?
Body-015682M
Trim-??
Paint-567(13122) Baroda Silver Metalic
Mr.Jones Offline
#2 Posted : Monday, 12 November 2007 11:21:39 PM(UTC)
Mr.Jones
V8 LS coupe
15682 HQ built in melb
13122 is Baroda Silver met
if the car had no options the base drivetrain would be
L32 =253 M15 =3spd GV1 = 3.08Sals
Voltaire
Bad-332 Offline
#3 Posted : Tuesday, 13 November 2007 12:15:36 AM(UTC)
Bad-332
The guy was told that it was factory fitted with a 350 (option L30) but there is no mention of it on the tags...He was also told that this often happened in the early HQ's?
The engine number is stamped with QU350.
Bad-332 Offline
#4 Posted : Tuesday, 13 November 2007 12:15:36 AM(UTC)
Bad-332
The guy was told that it was factory fitted with a 350 (option L30) but there is no mention of it on the tags...He was also told that this often happened in the early HQs?
JBM Offline
#5 Posted : Tuesday, 13 November 2007 2:43:42 AM(UTC)
JBM
QU is the engine number prefix for a Holden Chev in a HQ. I doubt that the engine number would actually be QU350.
James
#6 Posted : Tuesday, 13 November 2007 4:03:37 AM(UTC)
Firstly the car is not an early as it is a BHQ so it has head rests as standard. QU350## would be a Very very very late (infact they never numbered that high, they would have to of made 25000 350 engined cars to get there) Sydney engine and yours is a Mel
#7 Posted : Tuesday, 13 November 2007 6:22:19 AM(UTC)
Warren am I reading your post right? Aren't all HQ engines consecutive? Hence QU350xx or QU350xxx is quite possible? Although QU350xxx is a little bit too late for a 10/71 LS350.
If we all had th
#8 Posted : Tuesday, 13 November 2007 6:22:19 AM(UTC)
Warren am I reading your post right? Arent all HQ engines consecutive? Hence QU350xx or QU350xxx is quite possible? Although QU350xxx is a little bit too late for a 10/71 LS350.
If we all had the
#9 Posted : Tuesday, 13 November 2007 5:25:12 PM(UTC)
No Byron not all HQ engines were consecutive, only the Holden engines were consecutive, Chev engines were like they always were, numbered per plant. Sydney was designated engine numbers 10000 to 39999, so 350## would be a Sydney engine, therefore 25000 35
Bad-332 Offline
#10 Posted : Tuesday, 13 November 2007 7:00:22 PM(UTC)
Bad-332
Engine Number: (Stamped on a pad at the front of the right hand cylinder bank, with prefix)
QU =HQ GTS 350
I'll check with my mate to see what the complete engine number is.
Bad-332 Offline
#11 Posted : Tuesday, 13 November 2007 7:00:22 PM(UTC)
Bad-332
QU =HQ GTS 350
Ill check with my mate to see what the complete engine number is.
Bad-332 Offline
#12 Posted : Wednesday, 14 November 2007 12:56:41 AM(UTC)
Bad-332
The engine number is as follows, it doesnt start with QU after all...
engine No VO208TYZ
Bad-332 Offline
#13 Posted : Wednesday, 14 November 2007 12:56:41 AM(UTC)
Bad-332
The engine number is as follows, it doesn't start with QU after all...
engine No VO208TYZ
Guest (13)
This page was generated in 0.088 seconds.
