Fastlane
Holden Forums
Holden General Discussion
And this one as well, HQ Coupe ID required
81237QJ303838 10/71-BHQ16058M Mod-HQ81237 LS Sports V8 3sp 3.08 diff? Body-015682M Trim-?? Paint-567(13122) Baroda Silver Metalic
V8 LS coupe 15682 HQ built in melb 13122 is Baroda Silver met if the car had no options the base drivetrain would be L32 =253 M15 =3spd GV1 = 3.08Sals |
"Planet earth is the asylum to which the rest of the universe sends it's lunatics" Voltaire |
The guy was told that it was factory fitted with a 350 (option L30) but there is no mention of it on the tags...He was also told that this often happened in the early HQ's? The engine number is stamped with QU350.
Cheers |
Cheers |
The guy was told that it was factory fitted with a 350 (option L30) but there is no mention of it on the tags...He was also told that this often happened in the early HQs? The engine number is stamped with QU350.
Cheers |
Cheers |
QU is the engine number prefix for a Holden Chev in a HQ. I doubt that the engine number would actually be QU350.
James
You only have to be in front at the end of the race. |
Firstly the car is not an early as it is a BHQ so it has head rests as standard. QU350## would be a Very very very late (infact they never numbered that high, they would have to of made 25000 350 engined cars to get there) Sydney engine and yours is a Mel
Warren am I reading your post right? Aren't all HQ engines consecutive? Hence QU350xx or QU350xxx is quite possible? Although QU350xxx is a little bit too late for a 10/71 LS350.
_______________________________________________________ If we all had th |
Warren am I reading your post right? Arent all HQ engines consecutive? Hence QU350xx or QU350xxx is quite possible? Although QU350xxx is a little bit too late for a 10/71 LS350.
_______________________________________________________ If we all had the |
No Byron not all HQ engines were consecutive, only the Holden engines were consecutive, Chev engines were like they always were, numbered per plant. Sydney was designated engine numbers 10000 to 39999, so 350## would be a Sydney engine, therefore 25000 35
Engine Number: (Stamped on a pad at the front of the right hand cylinder bank, with prefix) QU =HQ GTS 350
I'll check with my mate to see what the complete engine number is.
Cheers |
Cheers |
Ill check with my mate to see what the complete engine number is.
Cheers |
Cheers |
The engine number is as follows, it doesnt start with QU after all...
engine No VO208TYZ
Cheers |
Cheers |
The engine number is as follows, it doesn't start with QU after all...
engine No VO208TYZ
Cheers |
Cheers |
Fastlane
Holden Forums
