#1 Posted : Saturday, 17 November 2007 1:21:48 AM(UTC)
can you bolt red 202 rods on a 3.3 crank ? cheers
#2 Posted : Saturday, 17 November 2007 1:35:32 AM(UTC)
Hi john.
A 202 & 3.3 are one in the same. You probably mean 'can you bolt 202 Red motor rods onto a 3.3 Blue motor crank ?
Yes you can, the big end journal sizes are all the same, you can fit Red rods onto a Blue crank or (more commonly) vice versa.
#3 Posted : Saturday, 17 November 2007 1:35:32 AM(UTC)
Hi john.
A 202 & 3.3 are one in the same. You probably mean can you bolt 202 Red motor rods onto a 3.3 Blue motor crank ?
#4 Posted : Saturday, 17 November 2007 2:03:48 AM(UTC)
thanks dr terry its that i just picked up a 3.3 crank and i read they are a fully counter weighted and are a better crank than early red 202 cheers ps
#5 Posted : Saturday, 17 November 2007 2:44:11 AM(UTC)
All red 202 cranks are the same. Its the blue/black that are counterweighted.
#6 Posted : Saturday, 17 November 2007 2:44:11 AM(UTC)
All red 202 cranks are the same. It's the blue/black that are counterweighted.
#7 Posted : Saturday, 17 November 2007 3:07:39 AM(UTC)
Hi Guys.
I think you may have balance issues if you use the lighter Red rods on a Blue crank. Arent the counterweights calculated to balance out the combined weight of the piston & rod assembly.
Dr Terry.
#8 Posted : Saturday, 17 November 2007 3:07:39 AM(UTC)
Hi Guys.
I think you may have balance issues if you use the lighter Red rods on a Blue crank. Aren't the counterweights calculated to balance out the combined weight of the piston & rod assembly.
Dr Terry.
boom Offline
#9 Posted : Saturday, 17 November 2007 6:14:33 AM(UTC)
boom
Blue rods are incredibly strong as well. Yes i think the counterweights are designed to balance it all out.
If it doesn’t burn fossil fuels, it’s not a sport.
vintageholden Offline
#10 Posted : Saturday, 17 November 2007 7:49:20 PM(UTC)
vintageholden
arnt black rods starfire....and stronger still
#11 Posted : Saturday, 17 November 2007 9:05:27 PM(UTC)
Starfire, blue, black - all the same. Virtually identical to XU-1 as well.
#12 Posted : Sunday, 18 November 2007 12:13:59 AM(UTC)
how do you i.d a starfire rod next to a std 186 rod?
#13 Posted : Sunday, 18 November 2007 1:32:09 AM(UTC)
Hi Mikey.
If you have them sitting next to each other, the Starfire/Blue/Black rod is beefier (more metal in the important areas) & the bolts are thicker.
Dr Terry.
#14 Posted : Tuesday, 20 November 2007 2:18:55 AM(UTC)
thanks all the 3.3 crank i picked up is a blue motor crank so i will have t o go for the star fire rods to make it all work properly cheers ps i just thought a 202 red would run smoother with that combo
#15 Posted : Thursday, 22 November 2007 8:42:51 AM(UTC)
I thought red motors are neo seal, blue black are rope.
If this is the case. The cranks arent a straight swap.
Someone will need to confirm this though.
Cheers.
#16 Posted : Thursday, 22 November 2007 8:42:51 AM(UTC)
If this is the case. The cranks aren't a straight swap.
Cheers.
#17 Posted : Thursday, 22 November 2007 3:52:45 PM(UTC)
Not correct. Reds are neoprene up till some time in the early 70s. After that they are rope.
#18 Posted : Thursday, 22 November 2007 3:52:45 PM(UTC)
Not correct. Reds are neoprene up till some time in the early 70's. After that they are rope.
This page was generated in 0.107 seconds.
