can you bolt red 202 rods on a 3.3 crank ? cheers
Hi john.
A 202 & 3.3 are one in the same. You probably mean 'can you bolt 202 Red motor rods onto a 3.3 Blue motor crank ?
Yes you can, the big end journal sizes are all the same, you can fit Red rods onto a Blue crank or (more commonly) vice versa. |
Hi john.
A 202 & 3.3 are one in the same. You probably mean can you bolt 202 Red motor rods onto a 3.3 Blue motor crank ?
thanks dr terry its that i just picked up a 3.3 crank and i read they are a fully counter weighted and are a better crank than early red 202 cheers ps
All red 202 cranks are the same. Its the blue/black that are counterweighted.
All red 202 cranks are the same. It's the blue/black that are counterweighted.
Hi Guys.
I think you may have balance issues if you use the lighter Red rods on a Blue crank. Arent the counterweights calculated to balance out the combined weight of the piston & rod assembly.
Dr Terry. |
Hi Guys.
I think you may have balance issues if you use the lighter Red rods on a Blue crank. Aren't the counterweights calculated to balance out the combined weight of the piston & rod assembly.
Dr Terry. |
Blue rods are incredibly strong as well. Yes i think the counterweights are designed to balance it all out.
If it doesn’t burn fossil fuels, it’s not a sport.
arnt black rods starfire....and stronger still
Starfire, blue, black - all the same. Virtually identical to XU-1 as well.
how do you i.d a starfire rod next to a std 186 rod?
Hi Mikey.
If you have them sitting next to each other, the Starfire/Blue/Black rod is beefier (more metal in the important areas) & the bolts are thicker.
Dr Terry. |
thanks all the 3.3 crank i picked up is a blue motor crank so i will have t o go for the star fire rods to make it all work properly cheers ps i just thought a 202 red would run smoother with that combo
I thought red motors are neo seal, blue black are rope. If this is the case. The cranks arent a straight swap. Someone will need to confirm this though. Cheers.
I thought red motors are neo seal, blue black are rope. If this is the case. The cranks aren't a straight swap. Someone will need to confirm this though. Cheers.
Not correct. Reds are neoprene up till some time in the early 70s. After that they are rope.
Not correct. Reds are neoprene up till some time in the early 70's. After that they are rope.
