Mr Void Offline
#1 Posted : Monday, 26 November 2007 7:11:26 AM(UTC)
Mr Void
Hi all,
I just bought a 10bolt sals, 3.08 LSD with discs - but no calipers.
Could someone tell me the best/easiest to find calipers to go on this diff?
Also, could anyone enlighten me regarding the h.brake 'probs' with disc rear ends (everyone says they have probs but no one says exactly what and if there is a fix??)
..and last q, will I need to change the std v8 booster setup in the tonner for the rear discs?
Thanks all
void
___________________
Why are you reading this, you should be looking up there^^
Joetech Tonner - coming soon!
___________________
vintageholden Offline
#2 Posted : Monday, 26 November 2007 9:25:47 AM(UTC)
vintageholden
CALLIPERS might be the same as commodore rear disk???
not sure of hand brake problems
booster should be the same
might have to change proprtion valve...
#3 Posted : Monday, 26 November 2007 4:20:12 PM(UTC)
Calipers are unique to HZ, WB and A9X although from memory the A9X uses a different handbrake bracket. The problem with the handbrake is it tends to sieze up as it is operated by a lever on the rear of the caliper that drives the piston against the discs.
Mr Void Offline
#4 Posted : Monday, 26 November 2007 8:41:36 PM(UTC)
Mr Void
Great! Thanks guys - I love getting straight, complete answers!!
Ok, so now your opinions, please?..
At the moment I have a 3.36 single spinner, drum rear on it. I really only bought the other diff for the lsd, the discs were a potential bonus (al
___________________
#5 Posted : Monday, 26 November 2007 9:37:59 PM(UTC)
Hi Mr Void.
Im not sure, but I dont think you can bolt a 3.36 gearset in place of a 3.08. From memory the offeset of the hemisphere is different.
#6 Posted : Monday, 26 November 2007 9:37:59 PM(UTC)
Hi Mr Void.
I'm not sure, but I don't think you can bolt a 3.36 gearset in place of a 3.08. From memory the offeset of the hemisphere is different.
#7 Posted : Monday, 26 November 2007 9:59:53 PM(UTC)
I think they do. From memory the 2.6 and 2.78 hemispheres are the same, and the 3.08 to 4.44 are the same. So you should be able to do a hemisphere swap, but use a diff place to set it up for you unless you have all the correct tools.
_________________
Mr Void Offline
#8 Posted : Monday, 26 November 2007 10:01:12 PM(UTC)
Mr Void
arhh, dont say that!!! Ill have to check it out - I thought 3.08 - 4.44 were the same but all the 2s were different.
bugga!
Thanks for letting me know though..
___________________
Joetec
___________________
Mr Void Offline
#9 Posted : Monday, 26 November 2007 10:01:12 PM(UTC)
Mr Void
arhh, don't say that!!! I'll have to check it out - I thought 3.08 - 4.44 were the same but all the 2's were different.
bugga!
___________________
Joe
___________________
#10 Posted : Wednesday, 28 November 2007 4:22:09 AM(UTC)
yeah i think the 2s are different.
With the rear hand brake bracket, if you lower the rear leafs using lowering blocks the bracket clears. I am not sure with reset rear leaf springs tho. Just got mine done and havent hooked up the brakes yet. I have some
Mr Void Offline
#11 Posted : Wednesday, 28 November 2007 8:21:48 AM(UTC)
Mr Void
cheers Sandman308 - yeah Ive got 2.5" blocks in the rear so hopefully thatll be enough.
If you want to shoot me an email with a price for the calipers that would be cool - Im in no rush though, Ill get the gears changed over at the same time I swap the d
___________________
Mr Void Offline
#12 Posted : Wednesday, 28 November 2007 8:21:48 AM(UTC)
Mr Void
cheers Sandman308 - yeah I've got 2.5" blocks in the rear so hopefully that'll be enough.
If you want to shoot me an email with a price for the calipers that would be cool - I'm in no rush though, I'll get the gears changed over at the same time I swap t
___________________
This page was generated in 0.083 seconds.
