Hi all,
I just bought a 10bolt sals, 3.08 LSD with discs - but no calipers.
Could someone tell me the best/easiest to find calipers to go on this diff?
Also, could anyone enlighten me regarding the h.brake 'probs' with disc rear ends (everyone says they have probs but no one says exactly what and if there is a fix??)
..and last q, will I need to change the std v8 booster setup in the tonner for the rear discs?
Thanks all void
___________________ Why are you reading this, you should be looking up there^^ Joetech Tonner - coming soon! |
___________________ - HJ turbotonner looks and goes like a sneezing rhino on heat! - |
CALLIPERS might be the same as commodore rear disk??? not sure of hand brake problems booster should be the same might have to change proprtion valve...
Calipers are unique to HZ, WB and A9X although from memory the A9X uses a different handbrake bracket. The problem with the handbrake is it tends to sieze up as it is operated by a lever on the rear of the caliper that drives the piston against the discs. |
Great! Thanks guys - I love getting straight, complete answers!!
Ok, so now your opinions, please?.. At the moment I have a 3.36 single spinner, drum rear on it. I really only bought the other diff for the lsd, the discs were a potential bonus (al |
Hi Mr Void.
Im not sure, but I dont think you can bolt a 3.36 gearset in place of a 3.08. From memory the offeset of the hemisphere is different.
Dr Terry |
Hi Mr Void.
I'm not sure, but I don't think you can bolt a 3.36 gearset in place of a 3.08. From memory the offeset of the hemisphere is different.
Dr Terry |
I think they do. From memory the 2.6 and 2.78 hemispheres are the same, and the 3.08 to 4.44 are the same. So you should be able to do a hemisphere swap, but use a diff place to set it up for you unless you have all the correct tools.
_________________ |
arhh, dont say that!!! Ill have to check it out - I thought 3.08 - 4.44 were the same but all the 2s were different.
bugga! Thanks for letting me know though..
___________________ Why are you reading this, you should be looking up there^^ Joetec |
arhh, don't say that!!! I'll have to check it out - I thought 3.08 - 4.44 were the same but all the 2's were different.
___________________ Why are you reading this, you should be looking up there^^ Joe |
yeah i think the 2s are different. With the rear hand brake bracket, if you lower the rear leafs using lowering blocks the bracket clears. I am not sure with reset rear leaf springs tho. Just got mine done and havent hooked up the brakes yet. I have some
cheers Sandman308 - yeah Ive got 2.5" blocks in the rear so hopefully thatll be enough. If you want to shoot me an email with a price for the calipers that would be cool - Im in no rush though, Ill get the gears changed over at the same time I swap the d |
cheers Sandman308 - yeah I've got 2.5" blocks in the rear so hopefully that'll be enough. If you want to shoot me an email with a price for the calipers that would be cool - I'm in no rush though, I'll get the gears changed over at the same time I swap t |
