HQ SAND MAN Offline
#1 Posted : Thursday, 29 November 2007 9:14:25 PM(UTC)
HQ SAND MAN
Hey guys as most of you know my PV has a 327 chev the motor is due to come out for a rebuild , can anyone give me their thoughts on the best suited internals for that motor ie pistons ,rings , bearings rods ect ,, cheers
Sandman Offline
#2 Posted : Saturday, 1 December 2007 6:02:16 AM(UTC)
Sandman
Is it a genuine 4"bore block? Not a 307 bored out etc. Is it still std bore(4") or has it been previously bored out?
If you are able to bore it .030"oversize safely, I would build a 383 out of it. Use 400 crank and rods and 350 forged pistons.
I bui
skydog Offline
#3 Posted : Saturday, 1 December 2007 8:51:01 AM(UTC)
skydog
Hi Sandman
I was looking at the specs of your engine and was wondering if you have any problems with it running hot?
The reason I ask is that I bought a 350 for the HQ Monaro and it has always run hot and most of the time will boil at low speed, if
adam PERTH Offline
#4 Posted : Saturday, 1 December 2007 8:55:02 AM(UTC)
adam PERTH
if its a soughtafter casting, sell your 327 as a runner.
buy a 350 4 bolt vortec long, with better heads than any early casting for $2880.
A1 Bogan.
HQ SAND MAN Offline
#5 Posted : Monday, 3 December 2007 11:40:38 PM(UTC)
HQ SAND MAN
hey guys , motor is 60thou , fulie heads , small cam , a/m manifold extractors ,holley ect ... I know its on its last bore , hence the question about the best stuff too use ,, cheers
boom Offline
#6 Posted : Tuesday, 4 December 2007 4:51:11 AM(UTC)
boom
ditch the block for a 350 chev bare block if it's 60thou over, they are about as cheap as a 308 block, there are a couple on ebay. Get an Eagle stroker crank (383) about $350 from most speed shops. pistons to suit, etc, you should get change for $1000 exc
boom Offline
#7 Posted : Tuesday, 4 December 2007 4:51:11 AM(UTC)
boom
ditch the block for a 350 chev bare block if its 60thou over, they are about as cheap as a 308 block, there are a couple on ebay. Get an Eagle stroker crank (383) about $350 from most speed shops. pistons to suit, etc, you should get change for $1000 excl
adam PERTH Offline
#8 Posted : Tuesday, 4 December 2007 7:42:46 AM(UTC)
adam PERTH
The old Cast chev blocks are virtually worthless these days, - $100. a 308 block would probably be worth more.
HQ sandman, you still haven't given us the casting number of the block, i sold a 60 thou 327 AUS for $2K over 5 years ago!.
so it still mayb
Edited by user Tuesday, 4 December 2007 7:48:19 AM(UTC)  | Reason: Not specified
adam PERTH Offline
#9 Posted : Tuesday, 4 December 2007 7:42:46 AM(UTC)
adam PERTH
HQ sandman, you still havent given us the casting number of the block, i sold a 60 thou 327 AUS for $2K over 5 years ago!.
so it still maybe
boom Offline
#10 Posted : Tuesday, 4 December 2007 8:07:33 AM(UTC)
boom
i dont think you can beat the 383 i just mentioned on value for money. Especially since all the ancilliaries are interchangeable. If your worried about cost, then the stroker is the way to go.
Eagle crank, Hypatec Hypereutectic Pistons, X rods from subur
boom Offline
#11 Posted : Tuesday, 4 December 2007 8:07:33 AM(UTC)
boom
i don't think you can beat the 383 i just mentioned on value for money. Especially since all the ancilliaries are interchangeable. If your worried about cost, then the stroker is the way to go.
adam PERTH Offline
#12 Posted : Tuesday, 4 December 2007 8:42:54 AM(UTC)
adam PERTH
that is providing he doesn't have a small journal 327.
STroker kits are for large journal, - i assume.
which, its a fairly good chance it is a small journal. 1962-67
Large journal 68-69.
But, it did have a Saginaw behind it, so he may be extra lucky,
adam PERTH Offline
#13 Posted : Tuesday, 4 December 2007 8:42:54 AM(UTC)
adam PERTH
that is providing he doesnt have a small journal 327.
But, it did have a Saginaw behind it, so he may be extra lucky, i
boom Offline
#14 Posted : Tuesday, 4 December 2007 9:54:36 PM(UTC)
boom
boom Offline
#15 Posted : Tuesday, 4 December 2007 9:54:36 PM(UTC)
boom
HQ SAND MAN Offline
#16 Posted : Tuesday, 4 December 2007 11:10:27 PM(UTC)
HQ SAND MAN
I would like too keep the 327 in it just too be a bit different , and yes it has a saginaw behind it , ??? i will get theese casting numbers and see what you guys can tell me from there ,, the main reason I want too stay with the motor is because its been
boom Offline
#17 Posted : Wednesday, 5 December 2007 3:48:37 AM(UTC)
boom
alright, whatever you like, but i'm telling you you'll be pleased with the 350, and the 327 doesn't have nearly as many parts following.
If it doesn’t burn fossil fuels, it’s not a sport.
boom Offline
#18 Posted : Wednesday, 5 December 2007 3:48:37 AM(UTC)
boom
alright, whatever you like, but im telling you youll be pleased with the 350, and the 327 doesnt have nearly as many parts following.
HQ SAND MAN Offline
#19 Posted : Wednesday, 5 December 2007 6:30:53 AM(UTC)
HQ SAND MAN
BOOM im not diputing what you say and thankyou for your imput its very much appriciated , and i may even go that path , just thought the 327 was a bit different ,, cheers
boom Offline
#20 Posted : Thursday, 6 December 2007 2:43:29 AM(UTC)
boom
oh, sorry, no insult intended.
Guest (10)
