#1 Posted : Thursday, 29 November 2007 10:53:29 PM(UTC)
Looking to remove flared arches for standard wheel arches.
Does anybody know the best way to fix up flared rear wheel arches for a coupe?
Is it possible to cut them out from a ute/sedan or are they too small for a coupe??
If someone can help me out with some info that would be much appreciated.
peter_flane Offline
#2 Posted : Saturday, 1 December 2007 4:34:25 AM(UTC)
peter_flane
Replace with original cutout sections from another model is the best way. Patience and skill, butt welded and metal finished, it will be like original. I would expect a very skilled person to charge between $1500-2000 to do a metal finished job on the rea
#3 Posted : Sunday, 2 December 2007 11:03:35 AM(UTC)
Thanks Peter smol in regards to your comments on the wheel arches. Cheers!!!
#4 Posted : Sunday, 2 December 2007 7:03:22 PM(UTC)
Be careful of other body shapes wheel arches. They are different. The reverse scolloped bit around the edge for example. I have 2 x HK 327's that need the same surgery. I have 3 x HK Monaro quarters for donors, but need another left hand one to get enough
#5 Posted : Sunday, 2 December 2007 7:03:22 PM(UTC)
Be careful of other body shapes wheel arches. They are different. The reverse scolloped bit around the edge for example. I have 2 x HK 327s that need the same surgery. I have 3 x HK Monaro quarters for donors, but need another left hand one to get enough.
Ado Offline
#6 Posted : Monday, 3 December 2007 3:23:48 AM(UTC)
Ado
Back when i was panelbeating we fixed up a valiant rear wheel arch by using a front guard from the opposite side. Worked out ok in the end.
