Looking to remove flared arches for standard wheel arches. Does anybody know the best way to fix up flared rear wheel arches for a coupe? Is it possible to cut them out from a ute/sedan or are they too small for a coupe?? If someone can help me out with some info that would be much appreciated.
Replace with original cutout sections from another model is the best way. Patience and skill, butt welded and metal finished, it will be like original. I would expect a very skilled person to charge between $1500-2000 to do a metal finished job on the rea |
Thanks Peter smol in regards to your comments on the wheel arches. Cheers!!!
Be careful of other body shapes wheel arches. They are different. The reverse scolloped bit around the edge for example. I have 2 x HK 327's that need the same surgery. I have 3 x HK Monaro quarters for donors, but need another left hand one to get enough |
Be careful of other body shapes wheel arches. They are different. The reverse scolloped bit around the edge for example. I have 2 x HK 327s that need the same surgery. I have 3 x HK Monaro quarters for donors, but need another left hand one to get enough. |
Back when i was panelbeating we fixed up a valiant rear wheel arch by using a front guard from the opposite side. Worked out ok in the end.
