5 Pages<1234>»
adam PERTH Offline
#21 Posted : Tuesday, 11 December 2007 9:33:58 AM(UTC)
adam PERTH
Boom, i have had some hot 6's
the problem i found (especially with Toyota gearboxes behind them) is that the clutch gives up.
you may have to go for a triple plate clutch as Peter said.
its hard to get all that power thru a std. holden 6 clutch
A1 B
adam PERTH Offline
#22 Posted : Tuesday, 11 December 2007 9:33:58 AM(UTC)
adam PERTH
Boom, i have had some hot 6s
A1 Bo
boom Offline
#23 Posted : Tuesday, 11 December 2007 9:37:42 AM(UTC)
boom
yeah ill probably have a look at that. im pumped now
If it doesn’t burn fossil fuels, it’s not a sport.
boom Offline
#24 Posted : Tuesday, 11 December 2007 9:37:42 AM(UTC)
boom
yeah i'll probably have a look at that. i'm pumped now
peter_flane Offline
#25 Posted : Tuesday, 11 December 2007 9:52:26 AM(UTC)
peter_flane
270kw. Clutch will be expensive. I can try and find out what they are using at work. I went manual shift Trimatic, as I was not finding much joy with clutch availablity for the torque I am producing. However you are making a high hp engine. Are you runnin
#26 Posted : Tuesday, 11 December 2007 4:22:04 PM(UTC)
Originally posted by boom
i'd like to beat 308s rather than use one. this combo should make 270kW, meaning i can blow a
#27 Posted : Tuesday, 11 December 2007 4:22:04 PM(UTC)
id like to beat 308s rather than use one. this combo should make 270kW, meaning i can blow aw
boom Offline
#28 Posted : Tuesday, 11 December 2007 6:39:18 PM(UTC)
boom
ahh, a muncie would be good, are they 5sp? i've heard they're really strong. do CRS sell the adaptor plates? and would the conversion be harder/easier or cheaper/more expensive than a Supra conversion?
boom Offline
#29 Posted : Tuesday, 11 December 2007 6:39:18 PM(UTC)
boom
ahh, a muncie would be good, are they 5sp? ive heard theyre really strong. do CRS sell the adaptor plates? and would the conversion be harder/easier or cheaper/more expensive than a Supra conversion?
boom Offline
#30 Posted : Tuesday, 11 December 2007 6:45:32 PM(UTC)
boom
oh, peter i'm not quite sure what CFM the throttlebody will be yet. But yes it will be GRA gear.
also, a V8 aussie 4sp wouldn't be able to handle the power/torque will it? i was looking at the Nissan Stanza 5 speeds. How strong are they?
Edited by user Friday, 14 December 2007 5:57:33 AM(UTC)  | Reason: Not specified
boom Offline
#31 Posted : Tuesday, 11 December 2007 6:45:32 PM(UTC)
boom
oh, peter im not quite sure what CFM the throttlebody will be yet. But yes it will be GRA gear.
also, a V8 aussie 4sp wouldnt be able to handle the power/torque will it? i was looking at the Nissan Stanza 5 speeds. How strong are they?
#32 Posted : Tuesday, 11 December 2007 7:37:48 PM(UTC)
#33 Posted : Tuesday, 11 December 2007 7:37:48 PM(UTC)
boom Offline
#34 Posted : Tuesday, 11 December 2007 7:42:03 PM(UTC)
boom
What about a toploader? any idea on a clutch i should use? peter said go with triple plate. that sounds like a good choice.
#35 Posted : Tuesday, 11 December 2007 10:36:32 PM(UTC)
#36 Posted : Tuesday, 11 December 2007 10:36:32 PM(UTC)
boom Offline
#37 Posted : Tuesday, 11 December 2007 10:53:14 PM(UTC)
boom
sorry, i don't want an auto. Are muncies easy to come by?? how expensive are they? and i think i will go with the WB tonner clutch, but will they bolt to the Blue flywheel? or do you mean off a blue WB motor? i a bit lost
If it d
boom Offline
#38 Posted : Tuesday, 11 December 2007 10:53:14 PM(UTC)
boom
sorry, i dont want an auto. Are muncies easy to come by?? how expensive are they? and i think i will go with the WB tonner clutch, but will they bolt to the Blue flywheel? or do you mean off a blue WB motor? i a bit lost
If it do
#39 Posted : Tuesday, 11 December 2007 11:04:04 PM(UTC)
Hi boom.
A WB One-Tonner has a Blue motor.
I would go the auto as well, if you want reduced running costs & dont like pulling gearboxes in & out on a regular basis.
This has all been done many times before. I built a turbo Holden 6 back in the 7
#40 Posted : Tuesday, 11 December 2007 11:04:04 PM(UTC)
Hi boom.
I would go the auto as well, if you want reduced running costs & don't like pulling gearboxes in & out on a regular basis.
5 Pages<1234>»
