5 Pages<12345>
#41 Posted : Wednesday, 12 December 2007 2:19:42 AM(UTC)
Originally posted by Dr Terry
I did get sick of replacing clutches & Toyota 5-speeds.
Dr Terry.
#42 Posted : Wednesday, 12 December 2007 3:06:10 AM(UTC)
Hi Jim.
Yes, I used the needle roller bearing. As a matter of fact I think my box was the 1st in the country to use this. Back then we used to overhaul Jeff Dellows gearboxes for him & I remember the day he introduced us to that bearing. Jeff used to i
#43 Posted : Wednesday, 12 December 2007 3:06:10 AM(UTC)
Hi Jim.
Yes, I used the needle roller bearing. As a matter of fact I think my box was the 1st in the country to use this. Back then we used to overhaul Jeff Dellow's gearboxes for him & I remember the day he introduced us to that bearing. Jeff used to
boom Offline
#44 Posted : Wednesday, 12 December 2007 5:52:42 AM(UTC)
boom
ill probably go with the Supra turbo box (W58 steel case), apparantly they can take up to 650kW, and since ill only be running around 300, i think it will be a good choice. the celicas arent nearly as strong.
cheers boyz
If it
boom Offline
#45 Posted : Wednesday, 12 December 2007 5:52:42 AM(UTC)
boom
i'll probably go with the Supra turbo box (W58 steel case), apparantly they can take up to 650kW, and since i'll only be running around 300, i think it will be a good choice. the celicas aren't nearly as strong.
cheers boyz
If
peter_flane Offline
#46 Posted : Wednesday, 12 December 2007 10:02:26 AM(UTC)
peter_flane
I run a Trimatic with manual shift. This means if you have it in third gear, you will take off in third gear at the lights. So it is in reality a fully manual shift auto box. The thing you remove is the clutch. It works well for me as I am running about 1
boom Offline
#47 Posted : Wednesday, 12 December 2007 8:29:51 PM(UTC)
boom
yeah, but as i said, i want a manual, with a clutch. and i will also have double the amount of power of your car, meaning that to build up the trimatic, it will cost me alot more because i have to go up a stage. much more than a Supra turbo conversion.
#48 Posted : Wednesday, 12 December 2007 10:12:28 PM(UTC)
boom Offline
#49 Posted : Wednesday, 12 December 2007 10:52:46 PM(UTC)
boom
$10000 on internals? there's a torana with similar specs to this running nines with the same internals. he's running 30psi. That's 290kw at the wheels.
You're right about the other engine choices, but i'd rather stick with the 202.
I know that this is r
boom Offline
#50 Posted : Wednesday, 12 December 2007 10:52:46 PM(UTC)
boom
$10000 on internals? theres a torana with similar specs to this running nines with the same internals. hes running 30psi. Thats 290kw at the wheels.
Youre right about the other engine choices, but id rather stick with the 202.
I know that this is rather
#51 Posted : Thursday, 13 December 2007 4:12:14 AM(UTC)
Fair enough. What im getting at with the $10,000 bit is the cost to build the engine close to those output specs and making it last more than a few 1/4 mile runs ie to make it a daily driver. Sure it can be done. But it wont be cheap.
_________________
#52 Posted : Thursday, 13 December 2007 4:12:14 AM(UTC)
Fair enough. What i'm getting at with the $10,000 bit is the cost to build the engine close to those output specs and making it last more than a few 1/4 mile runs ie to make it a daily driver. Sure it can be done. But it won't be cheap.
_______________
boom Offline
#53 Posted : Thursday, 13 December 2007 4:57:16 AM(UTC)
boom
oh, just so you guys know, it wont be run at max boost all the time. Itll probably be on 10psi or so for the street.
If it doesn’t burn fossil fuels, it’s not a sport.
boom Offline
#54 Posted : Thursday, 13 December 2007 4:57:16 AM(UTC)
boom
oh, just so you guys know, it won't be run at max boost all the time. It'll probably be on 10psi or so for the street.
boom Offline
#55 Posted : Thursday, 13 December 2007 5:41:51 AM(UTC)
boom
here's the link to the torana running nines, the guy says that the motor will break the supra box in third gear from the torque produced though, so maybe a muncie or toploader are on the cards?? aren't there any strengthening kit for the supra and celica
boom Offline
#56 Posted : Thursday, 13 December 2007 5:41:51 AM(UTC)
boom
heres the link to the torana running nines, the guy says that the motor will break the supra box in third gear from the torque produced though, so maybe a muncie or toploader are on the cards?? arent there any strengthening kit for the supra and celica bo
#57 Posted : Thursday, 13 December 2007 6:23:39 AM(UTC)
Probably yes, but an auto can always be made tougher. The ideal engine to run in a Holden is something that bolts to a TH400, which unfortunately the Holden 6 doesnt. Which leads to another thought - a Chev 292 straight 6 done as you describe for the 202,
#58 Posted : Thursday, 13 December 2007 6:23:39 AM(UTC)
Probably yes, but an auto can always be made tougher. The ideal engine to run in a Holden is something that bolts to a TH400, which unfortunately the Holden 6 doesn't. Which leads to another thought - a Chev 292 straight 6 done as you describe for the 202
boom Offline
#59 Posted : Thursday, 13 December 2007 8:45:38 AM(UTC)
boom
thatd be cool!
boom Offline
#60 Posted : Thursday, 13 December 2007 8:45:38 AM(UTC)
boom
that'd be cool!
Guest (10)
5 Pages<12345>
