#1 Posted : Wednesday, 16 January 2008 6:29:47 AM(UTC)
Saw this on Ebay. Good way to make a factory 253 go a bit harder, while keeping it "standard".
http://cgi.ebay.com.au/2...WDVWQQrdZ1QQcmdZViewItem
#2 Posted : Wednesday, 16 January 2008 8:11:27 PM(UTC)
Sounds like this guy on ebay has NO IDEA of whats in his motor....
Yet another great reason to rebuild a standard 308.. After the stroker crank and rods and $$$$ spent its still 22 cubes down on a bog stocker 308...
Wonder how much it would weigh ??
#3 Posted : Wednesday, 16 January 2008 8:11:27 PM(UTC)
Sounds like this guy on ebay has NO IDEA of what's in his motor....
Yet another great reason to rebuild a standard 308.. After the stroker crank and rods and $$$$ spent it's still 22 cubes down on a bog stocker 308...
#4 Posted : Wednesday, 16 January 2008 10:08:24 PM(UTC)
It'd go harder than a 308 probably due to the 3.48" stroke. Much like a 307 goes harder than a 308. Not worth doing yourself if you have a 308, but worth it for what he's asking IF you have say a HZ 253 Sandman or GTS and want to keep it as original as po
#5 Posted : Wednesday, 16 January 2008 10:08:24 PM(UTC)
Itd go harder than a 308 probably due to the 3.48" stroke. Much like a 307 goes harder than a 308. Not worth doing yourself if you have a 308, but worth it for what hes asking IF you have say a HZ 253 Sandman or GTS and want to keep it as original as poss
musksell Offline
#6 Posted : Monday, 21 January 2008 12:30:21 AM(UTC)
musksell
Actually has 3.210 inch stroke or 81.53mm so not much use really....
There 310 stroker kit has the 88mm stroke.
info from wwww.pro-stroke.com.au
#7 Posted : Monday, 21 January 2008 1:21:40 AM(UTC)
Easy mistake! (3.625/2)^2 x pi x 3.48 x 8 = 287.3ci.
If it had 307 pistons (which I doubt as this is a 250 thou overbore over std 253) with a 3.21" stroke it'd be a 303ci motor.
A std bore 253 with a 3.21" stroke is a 265ci engine. It looks like it
#8 Posted : Monday, 21 January 2008 1:21:40 AM(UTC)
If it had 307 pistons (which I doubt as this is a 250 thou overbore over std 253) with a 3.21" stroke itd be a 303ci motor.
A std bore 253 with a 3.21" stroke is a 265ci engine. It looks like it m
boom Offline
#9 Posted : Monday, 21 January 2008 1:28:02 AM(UTC)
boom
that's the reason no-one will buy it.
People know that there is no point in putting money into a 253, when you will yeild a ****load more power out of a 308 for the same price.
If nissan motorsport is nismo, then doesn't that mak
boom Offline
#10 Posted : Monday, 21 January 2008 1:28:02 AM(UTC)
boom
thats the reason no-one will buy it.
If nissan motorsport is nismo, then doesnt that make
#11 Posted : Monday, 21 January 2008 1:57:10 AM(UTC)
Its be a good thing at std bore and 3.48" stroke and would probably eat a 308. But as an offset ground thing with massive overbore I dont see the point.
If we all had the same (good) taste, who w
#12 Posted : Monday, 21 January 2008 1:57:10 AM(UTC)
It's be a good thing at std bore and 3.48" stroke and would probably eat a 308. But as an offset ground thing with massive overbore I don't see the point.
musksell Offline
#13 Posted : Monday, 21 January 2008 3:21:17 AM(UTC)
musksell
yea it is 3.77 bore with only one rebore
but the motor is new and balanced, otherwise somewhat a waste of money....when they could of done the 310 kit for $500 more and got alot more.
#14 Posted : Monday, 21 January 2008 5:00:35 AM(UTC)
Or did the same thing to a 308 and got 327 cubes or 350 cubes. Much better idea.
#15 Posted : Monday, 21 January 2008 10:49:13 PM(UTC)
whats the problem its all legit ****s
boom Offline
#16 Posted : Monday, 21 January 2008 11:29:46 PM(UTC)
boom
we know it's legit. it's just better to use a 308 from the start. you've spent all that money on a stroker, and you still don't have 5 litres. but hey, each to their own
If nissan motorsport is nismo, then doesn't that make honda m
boom Offline
#17 Posted : Monday, 21 January 2008 11:29:46 PM(UTC)
boom
we know its legit. its just better to use a 308 from the start. youve spent all that money on a stroker, and you still dont have 5 litres. but hey, each to their own
If nissan motorsport is nismo, then doesnt that make honda motors
#18 Posted : Tuesday, 22 January 2008 4:28:32 AM(UTC)
Problem is the massive overbore.
boom Offline
#19 Posted : Tuesday, 22 January 2008 6:02:51 AM(UTC)
boom
wow, just noticed that 250thou! holy ****.
boom Offline
#20 Posted : Tuesday, 22 January 2008 6:02:51 AM(UTC)
boom
Guest (5)
This page was generated in 0.082 seconds.
