Saw this on Ebay. Good way to make a factory 253 go a bit harder, while keeping it "standard". http://cgi.ebay.com.au/2...WDVWQQrdZ1QQcmdZViewItem_______________________________________________________ If we all had the same (good) taste, who would buy all the Fords? |
Sounds like this guy on ebay has NO IDEA of whats in his motor....
Yet another great reason to rebuild a standard 308.. After the stroker crank and rods and $$$$ spent its still 22 cubes down on a bog stocker 308...
Wonder how much it would weigh ??
Sounds like this guy on ebay has NO IDEA of what's in his motor....
Yet another great reason to rebuild a standard 308.. After the stroker crank and rods and $$$$ spent it's still 22 cubes down on a bog stocker 308...
It'd go harder than a 308 probably due to the 3.48" stroke. Much like a 307 goes harder than a 308. Not worth doing yourself if you have a 308, but worth it for what he's asking IF you have say a HZ 253 Sandman or GTS and want to keep it as original as po |
Itd go harder than a 308 probably due to the 3.48" stroke. Much like a 307 goes harder than a 308. Not worth doing yourself if you have a 308, but worth it for what hes asking IF you have say a HZ 253 Sandman or GTS and want to keep it as original as poss |
You have been a member since:: 29/08/2005(UTC) Posts: 243
Actually has 3.210 inch stroke or 81.53mm so not much use really.... There 310 stroker kit has the 88mm stroke. info from w www.pro-stroke.com.au
Easy mistake! (3.625/2)^2 x pi x 3.48 x 8 = 287.3ci.
If it had 307 pistons (which I doubt as this is a 250 thou overbore over std 253) with a 3.21" stroke it'd be a 303ci motor.
A std bore 253 with a 3.21" stroke is a 265ci engine. It looks like it |
If it had 307 pistons (which I doubt as this is a 250 thou overbore over std 253) with a 3.21" stroke itd be a 303ci motor.
A std bore 253 with a 3.21" stroke is a 265ci engine. It looks like it m |
that's the reason no-one will buy it. People know that there is no point in putting money into a 253, when you will yeild a ****load more power out of a 308 for the same price.
If nissan motorsport is nismo, then doesn't that mak
thats the reason no-one will buy it. People know that there is no point in putting money into a 253, when you will yeild a ****load more power out of a 308 for the same price.
If nissan motorsport is nismo, then doesnt that make
Its be a good thing at std bore and 3.48" stroke and would probably eat a 308. But as an offset ground thing with massive overbore I dont see the point.
_______________________________________________________ If we all had the same (good) taste, who w |
It's be a good thing at std bore and 3.48" stroke and would probably eat a 308. But as an offset ground thing with massive overbore I don't see the point.
_______________________________________________________ If we all had the same (good) taste, who |
yea it is 3.77 bore with only one rebore
but the motor is new and balanced, otherwise somewhat a waste of money....when they could of done the 310 kit for $500 more and got alot more.
Or did the same thing to a 308 and got 327 cubes or 350 cubes. Much better idea.
whats the problem its all legit ****s
we know it's legit. it's just better to use a 308 from the start. you've spent all that money on a stroker, and you still don't have 5 litres. but hey, each to their own
If nissan motorsport is nismo, then doesn't that make honda m
we know its legit. its just better to use a 308 from the start. youve spent all that money on a stroker, and you still dont have 5 litres. but hey, each to their own
If nissan motorsport is nismo, then doesnt that make honda motors
Problem is the massive overbore.
wow, just noticed that 250thou! holy ****.
