Rhys Offline
#1 Posted : Wednesday, 23 January 2008 7:44:52 AM(UTC)
Rhys
Hi All,
Just wondering if anyone could give me an idea of the easiest way to undo the 9/16 bolt to adjust the timing easily? The auto transmission dipstick is in the way and I can undo it about 1/20 of a turn at a time, so not impossible but time consuming. Is there a special spanner that can be bought, or am I better off getting an old 9/16 spanner and bending it so it fits around everything easily?
thanks
Rhys
boom Offline
#2 Posted : Wednesday, 23 January 2008 8:06:11 AM(UTC)
boom
do you need the engine running? if not, pull of the manifold, saves you a heap of trouble.
boom Offline
#3 Posted : Wednesday, 23 January 2008 8:06:11 AM(UTC)
boom
JBM Offline
#4 Posted : Wednesday, 23 January 2008 8:29:25 AM(UTC)
JBM
You could try one of those new ratchet type ring spanners, might be a bit bulky though. I have tried replacing this bolt with a socket head screw because of access in my Torana but it was worse.
James
#5 Posted : Wednesday, 23 January 2008 4:18:22 PM(UTC)
What about a Metrinch 14-15mm socket with one of those flexi extensions, to loosen it. Then cut a 9/16"AF ring spanner cut to about 2" long to turn it for distributor adjustment and to tighten it as much as possible before using the extension again. You c
#6 Posted : Wednesday, 23 January 2008 4:49:13 PM(UTC)
This must be a prob isolated to WBs (and HQ-Z retro-fitted with HEI) because theres enough room in a commodore for a regular (say 5 inches long) 9/16 to fit and turn the dizzy bolt.
_____________________________________________________
#7 Posted : Wednesday, 23 January 2008 4:49:13 PM(UTC)
This must be a prob isolated to WBs (and HQ-Z retro-fitted with HEI) because there's enough room in a commodore for a regular (say 5 inches long) 9/16 to fit and turn the dizzy bolt.
#8 Posted : Wednesday, 23 January 2008 6:01:58 PM(UTC)
Hi Guys.
There is a special spanner designed for just this problem.
Its made by the yanks, because this was a common problem on most V8s. Has anyone on this forum tried to loosen the dissy bolt on a Ford Cleveland with A/Cond?
The tool comes in 2
Edited by user Wednesday, 23 January 2008 6:03:04 PM(UTC)  | Reason: Not specified
#9 Posted : Wednesday, 23 January 2008 6:01:58 PM(UTC)
Hi Guys.
It's made by the yanks, because this was a common problem on most V8s. Has anyone on this forum tried to loosen the dissy bolt on a Ford Cleveland with A/Cond?
The tool comes in
Rhys Offline
#10 Posted : Wednesday, 23 January 2008 8:05:48 PM(UTC)
Rhys
Thanks a lot for the help guys. I'll be buying one of those KD Tools clamp wrenches asap! I think it will pay for itself straight away as it'll take 2 minutes versus 20 minutes. If all else fails I can cut down an old 9/16 spanner.
Mick maybe the auto
Rhys Offline
#11 Posted : Wednesday, 23 January 2008 8:05:48 PM(UTC)
Rhys
Thanks a lot for the help guys. Ill be buying one of those KD Tools clamp wrenches asap! I think it will pay for itself straight away as itll take 2 minutes versus 20 minutes. If all else fails I can cut down an old 9/16 spanner.
Mick maybe the auto tr
JBM Offline
#12 Posted : Wednesday, 23 January 2008 8:19:48 PM(UTC)
JBM
Its USD17.41 on Amazon + postage. http://www.amazon.com/KD...tor-Wrench/dp/B0002STSCQ
Would it be cheaper locally?
James
Edited by user Wednesday, 23 January 2008 8:21:35 PM(UTC)  | Reason: Not specified
#13 Posted : Thursday, 24 January 2008 2:56:43 AM(UTC)
Rhys am i pretty sure i have seen them at supercheap autos.
They also have the 3/8 drive flexi head ratchets to do the spark plugs.
Those 2 tools are a must for V8 owners.
Cheers...Mario
