Fastlane
Holden Forums
Holden General Discussion
Getting to Blue V8 distributor clamp bolt
Hi All,
Just wondering if anyone could give me an idea of the easiest way to undo the 9/16 bolt to adjust the timing easily? The auto transmission dipstick is in the way and I can undo it about 1/20 of a turn at a time, so not impossible but time consuming. Is there a special spanner that can be bought, or am I better off getting an old 9/16 spanner and bending it so it fits around everything easily?
thanks Rhys
do you need the engine running? if not, pull of the manifold, saves you a heap of trouble.
You could try one of those new ratchet type ring spanners, might be a bit bulky though. I have tried replacing this bolt with a socket head screw because of access in my Torana but it was worse.
James
You only have to be in front at the end of the race. |
What about a Metrinch 14-15mm socket with one of those flexi extensions, to loosen it. Then cut a 9/16"AF ring spanner cut to about 2" long to turn it for distributor adjustment and to tighten it as much as possible before using the extension again. You c |
This must be a prob isolated to WBs (and HQ-Z retro-fitted with HEI) because theres enough room in a commodore for a regular (say 5 inches long) 9/16 to fit and turn the dizzy bolt.
Mick _____________________________________________________ |
This must be a prob isolated to WBs (and HQ-Z retro-fitted with HEI) because there's enough room in a commodore for a regular (say 5 inches long) 9/16 to fit and turn the dizzy bolt.
Mick ____________________________________________________ |
Hi Guys. There is a special spanner designed for just this problem. Its made by the yanks, because this was a common problem on most V8s. Has anyone on this forum tried to loosen the dissy bolt on a Ford Cleveland with A/Cond? The tool comes in 2 Edited by user Wednesday, 23 January 2008 6:03:04 PM(UTC)
| Reason: Not specified |
Hi Guys. There is a special spanner designed for just this problem. It's made by the yanks, because this was a common problem on most V8s. Has anyone on this forum tried to loosen the dissy bolt on a Ford Cleveland with A/Cond? The tool comes in Edited by user Wednesday, 23 January 2008 6:03:04 PM(UTC)
Thanks a lot for the help guys. I'll be buying one of those KD Tools clamp wrenches asap! I think it will pay for itself straight away as it'll take 2 minutes versus 20 minutes. If all else fails I can cut down an old 9/16 spanner.
Mick maybe the auto
Thanks a lot for the help guys. Ill be buying one of those KD Tools clamp wrenches asap! I think it will pay for itself straight away as itll take 2 minutes versus 20 minutes. If all else fails I can cut down an old 9/16 spanner.
Mick maybe the auto tr
Its USD17.41 on Amazon + postage. http://www.amazon.com/KD...tor-Wrench/dp/B0002STSCQ Would it be cheaper locally? James ------------------------------ Edited by user Wednesday, 23 January 2008 8:21:35 PM(UTC)
Rhys am i pretty sure i have seen them at supercheap autos. They also have the 3/8 drive flexi head ratchets to do the spark plugs. Those 2 tools are a must for V8 owners. Cheers...Mario
Fastlane
Holden Forums
