Is there any probs with fitting a VK injected engine with trimatic up to a HR/HD?? Thanks Eddie
"With A Name Like Brock What Else Would I Drive" |
Hi Vulcan
Ive done a few of these.
The main drama is the extractors hitting the chassis rail.
If you swap the sump, oil pick-up & fit the early dipstick tube into the block, the engine and transmission is a bolt-in job, using a Powerglide crossme |
Hi Vulcan
I've done a few of these.
If you swap the sump, oil pick-up & fit the early dipstick tube into the block, the engine and transmission is a bolt-in job, using a Powerglide crossm |
The conversions I have done to EH's I use WB Blue motor extractors as they are set up narrower, than Commodore. They are not the same as some exhaust shops tried to tell me. I used Walker Motorvater on the last few. This may be relevant to HR setups. |
The conversions I have done to EHs I use WB Blue motor extractors as they are set up narrower, than Commodore. They are not the same as some exhaust shops tried to tell me. I used Walker Motorvater on the last few. This may be relevant to HR setups. |
