vulcan2509 Offline
#1 Posted : Wednesday, 23 January 2008 5:42:53 PM(UTC)
vulcan2509
Is there any probs with fitting a VK injected engine with trimatic up to a HR/HD??
Eddie
"With A Name Like Brock What Else Would I Drive"
#2 Posted : Wednesday, 23 January 2008 6:08:23 PM(UTC)
Hi Vulcan
Ive done a few of these.
The main drama is the extractors hitting the chassis rail.
If you swap the sump, oil pick-up & fit the early dipstick tube into the block, the engine and transmission is a bolt-in job, using a Powerglide crossme
#3 Posted : Wednesday, 23 January 2008 6:08:23 PM(UTC)
Hi Vulcan
I've done a few of these.
peter_flane Offline
#4 Posted : Thursday, 24 January 2008 5:08:14 AM(UTC)
peter_flane
The conversions I have done to EH's I use WB Blue motor extractors as they are set up narrower, than Commodore. They are not the same as some exhaust shops tried to tell me. I used Walker Motorvater on the last few. This may be relevant to HR setups.
peter_flane Offline
#5 Posted : Thursday, 24 January 2008 5:08:14 AM(UTC)
peter_flane
The conversions I have done to EHs I use WB Blue motor extractors as they are set up narrower, than Commodore. They are not the same as some exhaust shops tried to tell me. I used Walker Motorvater on the last few. This may be relevant to HR setups.
