Mr.Jones Offline
#1 Posted : Thursday, 24 January 2008 8:57:00 AM(UTC)
Mr.Jones
Does anybody know the daily output of the various factories as I have 2 9/78 Pagewood tags with the body numbers about 260 apart, the chassis numbers are just over 300. Were they built on the same day (unlikely) 1 or 2 days apart (more likely) or a week apart?
TIA Leroy
Voltaire
boom Offline
#2 Posted : Saturday, 26 January 2008 4:31:01 AM(UTC)
boom
all i can say, is that holden is cutting jobs from its plant in Elizabeth because the VE is too efficient, the VE would be done in the same day.
boom Offline
#3 Posted : Saturday, 26 January 2008 4:31:01 AM(UTC)
boom
all i can say, is that holden is cutting jobs from it's plant in Elizabeth because the VE is too efficient, the VE would be done in the same day.
#4 Posted : Saturday, 26 January 2008 4:49:42 PM(UTC)
I found out that Holdens in Eliz has taken back the export preparation jobs and sunroofs from HBD and will run it with its own employees.
#5 Posted : Saturday, 26 January 2008 7:23:27 PM(UTC)
They made 154,155 HZs at 4 plants but Sydney and Adelaide were the big ones, so I would suggest maybe 1/3 at Pagewood.
Made between 10/77 and about 3/80, about 29 months
So monthly output would be 5315 a month or 170 to 250 a day depending on how ma
keithholden Offline
#6 Posted : Sunday, 27 January 2008 7:39:23 AM(UTC)
keithholden
We built 8 cars an hour at Trentham Upper Hutt General Motors back in 1984 about 1000 people worked there
boom Offline
#7 Posted : Sunday, 27 January 2008 8:33:47 AM(UTC)
boom
in wellington right? i saw a few VLs which had the SR20/RB20? instead of the usual RB30, the only way i could tell was that it said "2.0 electronic injection" is this right?
boom Offline
#8 Posted : Sunday, 27 January 2008 8:33:47 AM(UTC)
boom
#9 Posted : Sunday, 27 January 2008 7:57:59 PM(UTC)
Hi Guys.
Yes, that is correct, the RB20-E (2.0-litre 6-cyl) was available for VLs made in NZ.
#10 Posted : Monday, 28 January 2008 2:33:48 AM(UTC)
When I worked at GMH Eliz back in 87 we still had a few 2.0 VL`s comming down the line, near the end of the VL series we had a batch from a cancelled order for export we had to change the petrol tanks so they could be sold else where.
mmazz30 Offline
#11 Posted : Monday, 28 January 2008 8:43:55 PM(UTC)
mmazz30
I heard that a few RB20-E cylinder heads made its way onto RB30-E
bottom ends or was it the other way around?....I can't remember...old age taking over.
cheers...mario
mmazz30 Offline
#12 Posted : Monday, 28 January 2008 8:43:55 PM(UTC)
mmazz30
bottom ends or was it the other way around?....I cant remember...old age taking over.
cheers...mario
#13 Posted : Tuesday, 29 January 2008 8:01:33 AM(UTC)
Hi mario.
You heard correctly. I heard from several sources that quite a few (not sure how many) RB30-E engines, accidently had RB20-E heads fitted in Japan by Nissan. These things pinged very badly, because the only real difference was the smaller com
