Does anybody know the daily output of the various factories as I have 2 9/78 Pagewood tags with the body numbers about 260 apart, the chassis numbers are just over 300. Were they built on the same day (unlikely) 1 or 2 days apart (more likely) or a week apart? TIA Leroy |
"Planet earth is the asylum to which the rest of the universe sends it's lunatics" Voltaire |
all i can say, is that holden is cutting jobs from its plant in Elizabeth because the VE is too efficient, the VE would be done in the same day.
all i can say, is that holden is cutting jobs from it's plant in Elizabeth because the VE is too efficient, the VE would be done in the same day.
I found out that Holdens in Eliz has taken back the export preparation jobs and sunroofs from HBD and will run it with its own employees.
They made 154,155 HZs at 4 plants but Sydney and Adelaide were the big ones, so I would suggest maybe 1/3 at Pagewood.
Made between 10/77 and about 3/80, about 29 months
So monthly output would be 5315 a month or 170 to 250 a day depending on how ma
We built 8 cars an hour at Trentham Upper Hutt General Motors back in 1984 about 1000 people worked there
If its not broke it will be soon |
in wellington right? i saw a few VLs which had the SR20/RB20? instead of the usual RB30, the only way i could tell was that it said "2.0 electronic injection" is this right?
Hi Guys.
Yes, that is correct, the RB20-E (2.0-litre 6-cyl) was available for VLs made in NZ.
Dr Terry |
When I worked at GMH Eliz back in 87 we still had a few 2.0 VL`s comming down the line, near the end of the VL series we had a batch from a cancelled order for export we had to change the petrol tanks so they could be sold else where.
I heard that a few RB20-E cylinder heads made its way onto RB30-E bottom ends or was it the other way around?....I can't remember...old age taking over. cheers...mario
I heard that a few RB20-E cylinder heads made its way onto RB30-E bottom ends or was it the other way around?....I cant remember...old age taking over. cheers...mario
Hi mario.
You heard correctly. I heard from several sources that quite a few (not sure how many) RB30-E engines, accidently had RB20-E heads fitted in Japan by Nissan. These things pinged very badly, because the only real difference was the smaller com |
