#1 Posted : Friday, 25 January 2008 4:03:19 AM(UTC)
Hi guys I have a xb coupe 302 winsor , manual, how do I go buy fitting a T5 gearbox in it? would there be any major problems or can it be put in no worries with a V8 bell housing and is the clutch system the same?
Cheers Phill.
#2 Posted : Friday, 25 January 2008 10:40:44 PM(UTC)
There are a few different T5 gearboxes around all with different ratio's input shaft lengths and torque ratings.
Dellow or CRS both sell a sandwich plate that bolts onto your existing 4 speed bell housing and then you bolt the T5 to this plate. If
#3 Posted : Saturday, 26 January 2008 12:53:47 AM(UTC)
Thanks Jim, So I take it a T5 can fit, but what type of gearbox is correct and how do I know? using the same clutch system sounds good, thanks Jim.
Phill.
#4 Posted : Saturday, 26 January 2008 12:59:41 AM(UTC)
Sorry, me again, I would be doing a bit of freeway driving, so I need that extra gear for the overdrive down the road so it doesn't rev so much.
cheers Phill.
#5 Posted : Thursday, 31 January 2008 12:01:20 AM(UTC)
Dellow can advise on which T5 to use. For instance Commodore T5's use a very long input shaft and different splines to a Ford T5. I believe that the input shaft length is different between a 6 cylinder Falcon T5 and a V8 Falcon T5. I could be wrong on tha
#6 Posted : Thursday, 31 January 2008 2:20:30 AM(UTC)
Phill, some of this may be relevant to you too such as cross member etc.
http://www.fordforums.co...owthread.php?t=11201557
A good way for stat
