#1 Posted : Saturday, 26 January 2008 7:11:54 AM(UTC)
a mate just bought a 253 motor, engine # QR4003 it would be the lowest I`v ever come accross from a HQ.
boom Offline
#2 Posted : Saturday, 26 January 2008 7:35:10 AM(UTC)
boom
i wonder what the lowest (first) 253 engine number is? just out of interest, do you know terry?
Edited by user Saturday, 26 January 2008 7:38:14 AM(UTC)  | Reason: Not specified
boom Offline
#3 Posted : Saturday, 26 January 2008 7:35:10 AM(UTC)
boom
#4 Posted : Saturday, 26 January 2008 7:15:21 PM(UTC)
The lowest W series (ie HQ on) engine with a Q prefix will be Qx1001. The x may have been a 253, but it also could be anywhere from a 130 up to a 350. The first 253 will probably be the one out of the Hurricane.
________________________________________
#5 Posted : Saturday, 26 January 2008 7:27:15 PM(UTC)
Byron, will not be a 350 "anything but a 350" is what it should read.
Warren
boom Offline
#6 Posted : Saturday, 26 January 2008 8:44:24 PM(UTC)
boom
i was wondering how the 350 chev bolts into the HQ. does it use the same mounting points as the 253/308?
boom Offline
#7 Posted : Saturday, 26 January 2008 8:44:24 PM(UTC)
boom
#8 Posted : Saturday, 26 January 2008 10:02:50 PM(UTC)
Yes. Just different mount adapters.
boom Offline
#9 Posted : Saturday, 26 January 2008 10:51:11 PM(UTC)
boom
what about 202/173 motors? is it the same crossmember?
boom Offline
#10 Posted : Saturday, 26 January 2008 10:51:11 PM(UTC)
boom
#11 Posted : Saturday, 26 January 2008 11:49:26 PM(UTC)
There is no crossmember as you see in a Commodore. The engine cradle is integral to the front subframe which is identical for all HQ-WB (except for the upper control arm mounting points for late HX onwards and the cut off nose and hence one bumper bar bol
boom Offline
#12 Posted : Sunday, 27 January 2008 12:15:05 AM(UTC)
boom
oh, ok, so all the different motors bolt up to the same mounting points right? thats a plus then
boom Offline
#13 Posted : Sunday, 27 January 2008 12:15:05 AM(UTC)
boom
oh, ok, so all the different motors bolt up to the same mounting points right? that's a plus then
#14 Posted : Sunday, 27 January 2008 3:19:45 AM(UTC)
Yes. Same as HK-HG and LH-UC except for the big block Opel 4cyl.
boom Offline
#15 Posted : Sunday, 27 January 2008 4:06:46 AM(UTC)
boom
is the 350/Muncie gearbox crossmember the same as an aussie 4 speed?
boom Offline
#16 Posted : Sunday, 27 January 2008 4:06:46 AM(UTC)
boom
#17 Posted : Sunday, 27 January 2008 4:22:36 AM(UTC)
No. Gearbox crossmembers vary in HQ-WB, and are different for sedan/wagon/stateman and ute/van/tonner (shorter). These are the types:
M15, M20, M21, M22, M40 6cyl and V8.
M41 (TH400) 308 and 350.
M38, M41 (TH350) 308.
MC7 (Muncie) 350.
__________
boom Offline
#18 Posted : Sunday, 27 January 2008 5:11:30 AM(UTC)
boom
o.k thanks
boom Offline
#19 Posted : Sunday, 27 January 2008 5:11:30 AM(UTC)
boom
o.k thanks
adam PERTH Offline
#20 Posted : Tuesday, 29 January 2008 8:48:46 PM(UTC)
adam PERTH
Bryon, you have listed M41 above as T350..
i have never seen this.
A1 Bogan.
Guest (10)
This page was generated in 0.158 seconds.
