a mate just bought a 253 motor, engine # QR4003 it would be the lowest I`v ever come accross from a HQ.
i wonder what the lowest (first) 253 engine number is? just out of interest, do you know terry?
If nissan motorsport is nismo, then doesn't that make honda motorsport Homo? Edited by user Saturday, 26 January 2008 7:38:14 AM(UTC)
| Reason: Not specified
If nissan motorsport is nismo, then doesnt that make honda motorsport Homo? Edited by user Saturday, 26 January 2008 7:38:14 AM(UTC)
The lowest W series (ie HQ on) engine with a Q prefix will be Qx1001. The x may have been a 253, but it also could be anywhere from a 130 up to a 350. The first 253 will probably be the one out of the Hurricane.
________________________________________ |
Byron, will not be a 350 "anything but a 350" is what it should read.
Warren
i was wondering how the 350 chev bolts into the HQ. does it use the same mounting points as the 253/308?
Yes. Just different mount adapters.
what about 202/173 motors? is it the same crossmember?
There is no crossmember as you see in a Commodore. The engine cradle is integral to the front subframe which is identical for all HQ-WB (except for the upper control arm mounting points for late HX onwards and the cut off nose and hence one bumper bar bol |
oh, ok, so all the different motors bolt up to the same mounting points right? thats a plus then
oh, ok, so all the different motors bolt up to the same mounting points right? that's a plus then
Yes. Same as HK-HG and LH-UC except for the big block Opel 4cyl.
is the 350/Muncie gearbox crossmember the same as an aussie 4 speed?
No. Gearbox crossmembers vary in HQ-WB, and are different for sedan/wagon/stateman and ute/van/tonner (shorter). These are the types:
M15, M20, M21, M22, M40 6cyl and V8. M41 (TH400) 308 and 350. M38, M41 (TH350) 308. MC7 (Muncie) 350.
__________ |
o.k thanks
o.k thanks
Bryon, you have listed M41 above as T350.. i have never seen this.
A1 Bogan. |
