Does anyone know how to tell a Canadian grey motor from one made in Australia |
lcj |
Hi lawrence.
There is no such thing as a Canadian grey motor, if you are referring to the Holden 6. The only ones made in North America are the 2 (or was 3) original prototypes & these are cast in Michigan USA, not Canada.
The early Holden 6 grey mo |
the 179 hp myth.
the 179 hp myth.
HP on the side of 308 blocks. And the XU-2 being an LJ.
Hi Guys.
I think we should start a Holden myth list.
Dr Terry. |
Hi Guys.
I think we should start a Holden 'myth' list.
Dr Terry. |
What about factory auto GTS327? Or the one doing the traps for years that no 307 4spd HK was ever made.
FX wagon?
FX wagon?
Oh yeah, The famous words "I heard" |
Hi Guys.
The one about the 307 manual not being available, was a mistake by one of our better known motoring journos. He read an early HK sales brochure (pre-Monaro) which states that the Powerglide was mandatory with the 307 V8, because back then no S |
we should start a list like you said.
This about 150 motors cast in canada comes from, page 70 in street machine hot holdens number 3. the first 3 prototypes tested in aus, in 1947 were entirely built in detroit. they say. The HP on the side of 308s block is true, but there are myths about
This about 150 motors cast in canada comes from, page 70 in street machine hot holdens number 3. the first 3 prototypes tested in aus, in 1947 were entirely built in detroit. they say. The HP on the side of 308's block is true, but there are myths about
HP on the early 179 and 308 blocks is certainly true. The myths are all about it actually meaning anything other than 179 or 308.
we know it's true that they had HP, but it didn't mean high performance, so these jokers on ebay who sell the 'block and forged crank for a bulletproof motor' are wrong.
we know its true that they had HP, but it didnt mean high performance, so these jokers on ebay who sell the block and forged crank for a bulletproof motor are wrong.
Now i had a HP 308 block. i do believe it had a steel crank. i taped the top of the crank with a hammer and it rang like a bell, the other 308 crank did not ring. the crank had HP on it where the other had 308. the HP had forge marks 3 to 5mm wide, the ot
