im looking at buying a set of alloy heads.
if a pair of assembled heads say flows 550hp whatdoes that mean?
engine power rating ???
also will aftermarket 350alloys fit on a original hk 307 motor??
u joking ???
come on surely some one can help with this one
Never heard the term Flow to HP Rating.
Only CFM (cubic feet/minute) It's done on a flow test rig measuring the volume of air through each port in a 1 minute time frame. These test rigs nowadays are all electronically controlled. Not like the ones I've
Only CFM (cubic feet/minute) Its done on a flow test rig measuring the volume of air through each port in a 1 minute time frame. These test rigs nowadays are all electronically controlled. Not like the ones Ive u
I think there is an equation for multiplying the CFM to get a horsepower figure. I think its somewhere around the x 2 mark.
Ill check my book at home and post the figure.
Rock n Roll |
Rock n Roll |
I'll check my book at home and post the figure.
Rock n Roll |
Rock n Roll |
If your thinking of using the Procomp alloy heads dont bother because they are no very good. Look here - http://www.gmh-torana.co...pic=18160&hl=alloy+headsJames
You |
You only have to be in front at the end of the race. |
yes, much better off working the VN heads with the $1500 youd spend on procomp. the COME alloys are $2500 bare. they are a very good head.
According to Max Ellery's "How to rebuild and hotrod Holden V8"..."to calculate horsepower, multiple CFM by 2.174."
Rock n Roll |
Rock n Roll |
According to Max Ellerys "How to rebuild and hotrod Holden V8"..."to calculate horsepower, multiple CFM by 2.174."
Rock n Roll |
Rock n Roll |
Shows you how silly a 350cfm carby on a 202 is.
how much do the black 202 heads flow?
220-230 or with a tidy up 250 -260
MONARO!!WHERE!!NICE |
Sorry for the confusion here, when referring to CFM it is the CFM of the heads not the carby.
The standard heads (XT5)exhaust flow 110 CFM on a blue 308. Using 110 * 2.174 = 240 odd horsepower.
Rock n Roll |
Rock n Roll |
and how far can they be opened up (regardless of airspeed, its for forced induction)
Yeh, Aftermarket alum or iron heads will fit a 307 chev. As someone else said, steer clear of pro comp stuff. These days it's cheaper to buy a new set of heads than getting old heads ported etc. Plus the aftermarket ones will usually flow better out of
Yeh, Aftermarket alum or iron heads will fit a 307 chev. As someone else said, steer clear of pro comp stuff. These days its cheaper to buy a new set of heads than getting old heads ported etc. Plus the aftermarket ones will usually flow better out of
