#1 Posted : Monday, 25 February 2008 3:25:43 AM(UTC)
im looking at buying a set of alloy heads.
if a pair of assembled heads say flows 550hp whatdoes that mean?
engine power rating ???
also will aftermarket 350alloys fit on a original hk 307 motor??
#2 Posted : Tuesday, 26 February 2008 5:36:47 AM(UTC)
u joking ???
come on surely some one can help with this one
ozchevy Offline
#3 Posted : Tuesday, 26 February 2008 11:15:07 AM(UTC)
ozchevy
Never heard the term Flow to HP Rating.
Only CFM (cubic feet/minute) It's done on a flow test rig measuring the volume of air through each port in a 1 minute time frame. These test rigs nowadays are all electronically controlled. Not like the ones I've
ozchevy Offline
#4 Posted : Tuesday, 26 February 2008 11:15:07 AM(UTC)
ozchevy
Only CFM (cubic feet/minute) Its done on a flow test rig measuring the volume of air through each port in a 1 minute time frame. These test rigs nowadays are all electronically controlled. Not like the ones Ive u
KiwiHQ Offline
#5 Posted : Tuesday, 26 February 2008 7:19:55 PM(UTC)
KiwiHQ
I think there is an equation for multiplying the CFM to get a horsepower figure. I think its somewhere around the x 2 mark.
Ill check my book at home and post the figure.
Rock n Roll
Rock n Roll
KiwiHQ Offline
#6 Posted : Tuesday, 26 February 2008 7:19:55 PM(UTC)
KiwiHQ
I'll check my book at home and post the figure.
Rock n Roll
Rock n Roll
JBM Offline
#7 Posted : Tuesday, 26 February 2008 8:19:31 PM(UTC)
JBM
If your thinking of using the Procomp alloy heads dont bother because they are no very good.
Look here - http://www.gmh-torana.co...pic=18160&hl=alloy+heads
James
You
boom Offline
#8 Posted : Tuesday, 26 February 2008 9:00:42 PM(UTC)
boom
yes, much better off working the VN heads with the $1500 youd spend on procomp. the COME alloys are $2500 bare. they are a very good head.
boom Offline
#9 Posted : Tuesday, 26 February 2008 9:00:42 PM(UTC)
boom
KiwiHQ Offline
#10 Posted : Wednesday, 27 February 2008 3:34:35 AM(UTC)
KiwiHQ
According to Max Ellery's "How to rebuild and hotrod Holden V8"..."to calculate horsepower, multiple CFM by 2.174."
Rock n Roll
Rock n Roll
KiwiHQ Offline
#11 Posted : Wednesday, 27 February 2008 3:34:35 AM(UTC)
KiwiHQ
According to Max Ellerys "How to rebuild and hotrod Holden V8"..."to calculate horsepower, multiple CFM by 2.174."
Rock n Roll
Rock n Roll
#12 Posted : Wednesday, 27 February 2008 5:58:56 AM(UTC)
Shows you how silly a 350cfm carby on a 202 is.
boom Offline
#13 Posted : Wednesday, 27 February 2008 6:03:01 AM(UTC)
boom
how much do the black 202 heads flow?
boom Offline
#14 Posted : Wednesday, 27 February 2008 6:03:01 AM(UTC)
boom
Davesmonaro68 Offline
#15 Posted : Wednesday, 27 February 2008 6:25:42 AM(UTC)
Davesmonaro68
220-230 or with a tidy up 250 -260
MONARO!!WHERE!!NICE
MONARO!!WHERE!!NICE
KiwiHQ Offline
#16 Posted : Wednesday, 27 February 2008 6:54:31 AM(UTC)
KiwiHQ
Sorry for the confusion here, when referring to CFM it is the CFM of the heads not the carby.
The standard heads (XT5)exhaust flow 110 CFM on a blue 308. Using 110 * 2.174 = 240 odd horsepower.
Rock n Roll
Rock n Roll
boom Offline
#17 Posted : Wednesday, 27 February 2008 7:01:03 AM(UTC)
boom
and how far can they be opened up (regardless of airspeed, its for forced induction)
boom Offline
#18 Posted : Wednesday, 27 February 2008 7:01:03 AM(UTC)
boom
Sandman Offline
#19 Posted : Wednesday, 27 February 2008 7:04:03 AM(UTC)
Sandman
Yeh, Aftermarket alum or iron heads will fit a 307 chev.
As someone else said, steer clear of pro comp stuff.
These days it's cheaper to buy a new set of heads than getting old heads ported etc. Plus the aftermarket ones will usually flow better out of
Sandman Offline
#20 Posted : Wednesday, 27 February 2008 7:04:03 AM(UTC)
Sandman
These days its cheaper to buy a new set of heads than getting old heads ported etc. Plus the aftermarket ones will usually flow better out of
Guest (10)
