YetAnotherForum.NET Help
3 Pages<123>
boom Offline
#21 Posted : Sunday, 9 March 2008 12:10:11 AM(UTC)
boom
yep, im hearing that the dual planes are good for bulk torque, rather than power like the single planes, and torque is what im after.
Torque Power and Harrop are the frontrunners in this field, but are a bit pricey - $880 for carbs, $1100 for injection.
boom Offline
#22 Posted : Sunday, 9 March 2008 12:10:11 AM(UTC)
boom
yep, i'm hearing that the dual planes are good for bulk torque, rather than power like the single planes, and torque is what i'm after.
boom Offline
#23 Posted : Sunday, 9 March 2008 8:19:42 AM(UTC)
boom
well guys, i just sold the injected 202 i was going to build up. im picking up a 304 short motor from a VN onwards (dont know which) commodore next weekend. pick and payless do them for $200. ill see what i can organise in regards to heads.
boom Offline
#24 Posted : Sunday, 9 March 2008 8:19:42 AM(UTC)
boom
well guys, i just sold the injected 202 i was going to build up. i'm picking up a 304 short motor from a VN onwards (don't know which) commodore next weekend. pick and payless do them for $200. i'll see what i can organise in regards to heads.
#25 Posted : Sunday, 9 March 2008 7:40:20 PM(UTC)
Try and get a late VR on. These are blank on the sides where VN-mid VR have 5.0L on the sides.
boom Offline
#26 Posted : Sunday, 9 March 2008 8:22:29 PM(UTC)
boom
Ill try, but the guy at the wreckers said they only come in from time to time. do you mean from a clearancing point of view?
I actually think they charge the same price from any 304 from VN to VT, so if i can find a VT 304, then bonus clearanced and roll
boom Offline
#27 Posted : Sunday, 9 March 2008 8:22:29 PM(UTC)
boom
I'll try, but the guy at the wreckers said they only come in from time to time. do you mean from a clearancing point of view?
#28 Posted : Monday, 10 March 2008 6:58:05 AM(UTC)
Yes. The blank sided blocks already have the rod reliefs for the 5.7L crank.
boom Offline
#29 Posted : Monday, 10 March 2008 7:11:08 AM(UTC)
boom
if i cant find one, then im not going to stress to much, because it wont take much to clearance it, and if i use H-Beams (down the track) I need the clearance the VR-VT blocks anyway, as they are clearanced for I beams only.
If nis
boom Offline
#30 Posted : Monday, 10 March 2008 7:11:08 AM(UTC)
boom
if i can't find one, then im not going to stress to much, because it won't take much to clearance it, and if i use H-Beams (down the track) I need the clearance the VR-VT blocks anyway, as they are clearanced for I beams only.
If n
adam PERTH Offline
#31 Posted : Tuesday, 11 March 2008 9:19:08 AM(UTC)
adam PERTH
Boom.
Have you researched if a zero deck height is optimal for forced induction??.
Zero deck height, usually says to me 10:1 , 11: 1 comp ratio with stockish mild heads.
i.e with 350
712 cc bore : 70 cc head + gasket cc (4 cc?).
You dont want t
Edited by user Tuesday, 11 March 2008 9:24:15 AM(UTC)  | Reason: Not specified
adam PERTH Offline
#32 Posted : Tuesday, 11 March 2008 9:19:08 AM(UTC)
adam PERTH
Boom.
i.e with 350
You don't want
boom Offline
#33 Posted : Thursday, 20 March 2008 9:14:24 AM(UTC)
boom
sorry buddy, i didn't see this post.
Umm, my plan is to go turbo later on, but lets just forget about that for now, because building a bottom end that will cope with the power will cost me way more than i can spend.
So: at the moment, i have been re
boom Offline
#34 Posted : Thursday, 20 March 2008 9:14:24 AM(UTC)
boom
sorry buddy, i didnt see this post.
So: at the moment, i have been res
Sandman Offline
#35 Posted : Thursday, 20 March 2008 11:19:26 AM(UTC)
Sandman
Id use a forged piston. Hyperutectics are just a higher class forged piston, but they still shatter the same. I saw a guy(just after hed given me a lecture on how good his hyperutectics were) go out for a run at Wbank. It grenaded in the burnout. When he
Sandman Offline
#36 Posted : Thursday, 20 March 2008 11:19:26 AM(UTC)
Sandman
I'd use a forged piston. Hyperutectics are just a higher class forged piston, but they still shatter the same. I saw a guy(just after he'd given me a lecture on how good his hyperutectics were) go out for a run at W'bank. It grenaded in the burnout. When
boom Offline
#37 Posted : Thursday, 20 March 2008 6:45:41 PM(UTC)
boom
it's supposed to be a daily driver, and i was leaning towards a forged piston, but they are just way too expensive for my budget. i understand that hypers aren't as strong as forged, but it's not a drag engine. it's for the street. studs are a must, and i
boom Offline
#38 Posted : Thursday, 20 March 2008 6:45:41 PM(UTC)
boom
its supposed to be a daily driver, and i was leaning towards a forged piston, but they are just way too expensive for my budget. i understand that hypers arent as strong as forged, but its not a drag engine. its for the street. studs are a must, and im no
boom Offline
#39 Posted : Thursday, 20 March 2008 7:22:32 PM(UTC)
boom
boom Offline
#40 Posted : Thursday, 20 March 2008 7:22:32 PM(UTC)
boom
Guest (15)
3 Pages<123>
This page was generated in 0.094 seconds.
