unclearthur Offline
#1 Posted : Friday, 4 April 2008 1:56:50 AM(UTC)
unclearthur
Hi all, I'm new to the forum so expect some weird questions.
I have owned a '76 Ford Transit for around 16 years and have now just started to look after her a bit better. Recently changing diff and placing disc brake front end under her. I'm now contemplating a 289-302 Windsor engine to put in it. It now runs a 200 6 cyl, (standard) 3 sp box. I need to know if it all will fit under the little bonnett!!!
Set up maybe v8 with C4 box???
Any suggestions or help would be grateful.
In-Transit
In-Transit
#2 Posted : Friday, 4 April 2008 11:56:11 PM(UTC)
BasketcaseBear on the Holden Forums has a 308 powered late model Transit. He would be able to talk clearances of a V8 better than anyone. I have sent him an email on the subject.
Jim...
I have a bog stock 302W and C4 currently sitting in my Ca
basketcasebear Offline
#3 Posted : Saturday, 5 April 2008 5:33:37 AM(UTC)
basketcasebear
hey unclearther,
yes i am the legend in my own lunchbox that put a 308 t400 into my 98 transit,,
UUmm, a 1976 is a whole new ballgame,
I knew i could put a v8 in it cause there are companies doing it,,as well as putting v6,s in them,
I was just silly
DOH!!!
#4 Posted : Sunday, 6 April 2008 7:09:48 AM(UTC)
A couple of questions so that I may be able to help you a little more.
1.Is your gearbox a 3 speed manual, BW35 or C4 auto?
2. is your 200 sump a front drop one as in Falcon or a rear drop one as in a Cortina?
3. would you like me to go an
unclearthur Offline
#5 Posted : Monday, 7 April 2008 7:17:49 PM(UTC)
unclearthur
Thanks guys,
Just a few answers to yours!
1: it's a three speed BW at the moment.
2: Sump is a front drop one!
3: Rails and susp, should be fine looks very strong.
4: Width was the problem at rear I was worrying about, most likely have to remove radi
In-Transit
#6 Posted : Tuesday, 8 April 2008 2:37:48 AM(UTC)
Ok than you are in luck the front drop sump means that a V8 Falcon sump should do the job.
The C4 is the same length as the 3 speed and has the same tailshaft yoke. This means if you drop the 302 and c4 in and bolt the gearbox mount up then you
#7 Posted : Tuesday, 8 April 2008 3:45:47 AM(UTC)
basketcasebear
hey unclearthur,
with my installation, i built a roobar at the front, and put the radiator in it!!
I could have just fitted the rad into the transit,,but it made no difference in the roo bar anyways??
there is a pic of the campervan of the melenium,,in
DOH!!!
unclearthur Offline
#8 Posted : Tuesday, 8 April 2008 7:20:26 PM(UTC)
unclearthur
Great, I will go further in depth now and see what I can come up with.
Talk soon.
Ian
In-Transit
In-Transit
Dmax Offline
#9 Posted : Wednesday, 9 April 2008 8:15:51 AM(UTC)
Dmax
My brother had an older transit van with a 250 cross flow in it. There was a whole lot of room under there. I would think that if a straight six would go in, a v8, being shorter would go in no troubles. Like it was said by someone else, you may have to
648hp Tunnel Rammed 351, It does not get any better
#10 Posted : Wednesday, 9 April 2008 8:29:19 AM(UTC)
basketcasebear
As Dmax says, i have seen them with six,s in them,, there is a bloke in melb that has about twenty of them, and at least half have sixes in them,,some are trasits, some are bedfords,, I am not sure, but the pan in them is bulged in the middle, so allows
DOH!!!
unclearthur Offline
#11 Posted : Thursday, 10 April 2008 6:56:47 PM(UTC)
unclearthur
I'm going to throw another question at you all. Say I kept the straight six in her and touch it up a bit and decided to rip out the three speed and replace with a 4 speed box, what box will actually fit straight on without major problems? Remember the old
In-Transit
#12 Posted : Friday, 11 April 2008 12:07:38 AM(UTC)
basketcasebear
hey unclearthur,
I am not sure,,but it seems to me, that you having a ford motor already in it, it would be far easier to put say a 4ltr 4.1 litre? in her, and they have heaps of get up and go?
some with nearly as much go as the v8,s??
when the other f
DOH!!!
unclearthur Offline
#13 Posted : Friday, 11 April 2008 1:22:08 AM(UTC)
unclearthur
Hi,
Yes it does have a ford motor in it a ( original blue motor)200 six coupled to a 3 speed manual. As mentioned I replaced the brakes with discs and diff with a 2.98 instead of original 4.36. Now I have problems taking off on hills using clutch....
I
In-Transit
#14 Posted : Friday, 11 April 2008 4:33:18 AM(UTC)
basketcasebear
hey unclear,,
i am not clear either..
what i thought was this...
instead of v8 and c4
put 4.1 or 4litre in to it, and leave 3speed as is, and diff as is??
but i have no idea, what is involved, it was just my thoughts?
where are all the ford gurus w
DOH!!!
unclearthur Offline
#15 Posted: : Friday, 11 April 2008 6:19:22 AM(UTC)
unclearthur
Hey Basketcasebear, my mistake, I read your post wrong. Anyway I appreciate the help, looking forward to some replies.
In-Transit
In-Transit
#16 Posted : Friday, 11 April 2008 7:04:33 AM(UTC)
I'm not at my computer much this week but re a 4 speed.
6cyl TC Cortinas had a toploader with it's external linkages. You would be very hard pressed to find one and if you did it would not be cheap. A V8 toploader can be fitted to a 6 cyl single ra
#17 Posted : Friday, 11 April 2008 7:26:34 AM(UTC)
basketcasebear
hey jim, arfa,
my ambo was horrible on fuel, great on gas, my 91 van is great on petrol consumption,,
could it just be good motor, bad motor?
the van is not injected, and is great,
bcb
ptpro
some men see things as they are, and ask "why"
DOH!!!
unclearthur Offline
#18 Posted : Friday, 11 April 2008 7:31:49 PM(UTC)
unclearthur
Jim5.0,
Thanks for the info, the three speed has the linkages on the side of box, coupled to the shift which to me is at the front just behind the bellhousing.
This places the shift as I'm driving on a mound (raised area) poking through to my left forw
In-Transit
#19 Posted : Saturday, 12 April 2008 8:10:26 AM(UTC)
I have just gone out and measured my single rail. The gearstick pokes out roughly 54CM back from where the gearbox meets the bell housing. Would moving the gear stick back ~half a metre put it between the seats or nearly into the cargo area?
I also mea
#20 Posted : Saturday, 12 April 2008 10:09:32 AM(UTC)
basketcasebear
hey jim,
i dont even know what "single rail is",,
so much to learn,,so little time,,
bcb
ptpro
I dream of things that never were, and say, "bloody ripper idea mate, lets try it",!!
DOH!!!
This page was generated in 0.080 seconds.
