2 Pages<12
#21 Posted : Saturday, 12 April 2008 10:54:01 AM(UTC)
A single rail is a Ford/Valiant/P76 Borg Warner 4 speed gearbox aptly named due
to the single rail that links the shifter to the rest of the box (clearly seen in this photo)
http://cgi.ebay.com.au/F...x-bellhousing-6cyl_W0QQi
unclearthur Offline
#22 Posted : Monday, 14 April 2008 7:10:21 PM(UTC)
unclearthur
JIM5.0, thanks for the pic, all making sense now, pity I wasn't in Vic...
pick up only. I'm sure I will find one where I am here.
I believe the 4 speed will do the job, will sit back a bit but can't really see it being to big a problem.
Now I have to d
In-Transit
#23 Posted : Tuesday, 15 April 2008 6:21:00 AM(UTC)
Alright then if you are going to go the way of the single rail all that you will need is the box, bellhousing (yes it's different to a 3 speed one) and gear stick. All up should cost about $50 if you bide your time.
Preferably look for a Cort
#24 Posted : Wednesday, 16 April 2008 10:01:02 PM(UTC)
Also forgot to mention that the Cortina and XD XE XF 6 cyl single rail bell housing has provision for a cable clutch whereas the XB-XC versions and all V8 ones were hydraulic.
unclearthur Offline
#25 Posted : Thursday, 17 April 2008 7:18:18 PM(UTC)
unclearthur
Ok, so this is what I require and further confirmation!
1: XF ford 6 cyl single rail gearbox 4 speed would be best?
2: Bellhousing is required as 3 speed is different?
3: I require the lowest ratio in first gear to solve the problem that I have, will
In-Transit
#26 Posted : Thursday, 17 April 2008 7:52:07 PM(UTC)
1: Yes but it's only the age and gearstick that make it better.
2: Yes 3 speed has one gearbox mounting hole in a different place and the large hole in the centre is smaller than a 4 speed. To enlarge that hole on a 3 speed box would require a bi
unclearthur Offline
#27 Posted : Thursday, 17 April 2008 8:06:54 PM(UTC)
unclearthur
Well that was quick!! Thanks for all the info, let you know the outcome later on down the track. For now, signing off!
In-Transit
In-Transit
2 Pages<12
