#1 Posted : Saturday, 10 May 2008 1:46:19 AM(UTC)
the altinator light in my hq 202 auto wont go out dispite a tight belt and changing to a recoed unit it doesant seam to be draining the battery any ideas ? oao thanks
#2 Posted : Saturday, 10 May 2008 2:03:39 AM(UTC)
now wheres the spelling nazi
#3 Posted : Saturday, 10 May 2008 2:46:44 AM(UTC)
lonemonaro Offline
#4 Posted : Sunday, 11 May 2008 8:01:24 AM(UTC)
lonemonaro
Hi John,
It might be a common fault like the XC Fords, when fitted with after market air conditioning. It drains the battery by not re-charging it properly.
I solved my problem by changing standard 55 amp alternator to 80 amp, but still should have
Edited by user Sunday, 11 May 2008 8:05:50 AM(UTC)  | Reason: Not specified
#5 Posted : Sunday, 11 May 2008 6:11:53 PM(UTC)
And the teachers want more money in Vic, whats that for ? doing what they should have been doing all these years. Watch sky news, the text is full of it, they must have an editor. Can he spell?
#6 Posted : Tuesday, 13 May 2008 2:23:21 AM(UTC)
thanks george i dont have air on the car so i will try another alternator 120 amps or afresher battery sorry about the spelling wasnt the best what i lack in spelling i make up for in manners oao all the best
#7 Posted : Tuesday, 13 May 2008 2:57:05 AM(UTC)
Hi john.
What type of alternator is it, does it have a separate (external) regulator mounted on the radiator support panel or is it internal. Originally HQs had the external type. If you've already fitted a recond alternator, it could be a faulty regul
#8 Posted : Tuesday, 13 May 2008 2:57:05 AM(UTC)
Hi john.
What type of alternator is it, does it have a separate (external) regulator mounted on the radiator support panel or is it internal. Originally HQs had the external type. If youve already fitted a recond alternator, it could be a faulty regula
#9 Posted : Thursday, 15 May 2008 1:36:12 AM(UTC)
THANKS DR TERRY THE BATTERYS NOT GOING FLAT THE ALTERNATOR HAS AN INTERNAL REGULATOR I DISCONNECTED THE KICKDOWWN SWITCH ON THROTTLE FOR THE AUTO NO RESULT I THINK THE PROBLEM MAY BE CAUSED BY THE REVERSING SWITCH DOWN ON THE COLUMN ANY THOUGHTS OAO THANK
#10 Posted : Thursday, 15 May 2008 2:56:38 AM(UTC)
Hi JOHN.
If the brightness of the alternator light changes when you select reverse, your ignition fuse is blown. This is why the light is on. The alternator will be OK.
#11 Posted : Saturday, 17 May 2008 1:37:03 AM(UTC)
thanks dr terry yes it does change brightness its driving me mad i will be glad to see the dam thing go out could be why the temp light wont go out had to disconnect that one even after fitting a new sender oao thanks
