hello can anyone help me identify this torana it is from a deceased estate from my uncle who worked at holdens as a enginneer
it is a LJ 2 door factory V8 it has numbers 82911JH991922 XW7 on a plate near the radiator. is it a xu1?
It is a GTR. Might be an XU-1. What is its engine number?
It is a GTR. Might be an XU-1. What is it's engine number?
hi bryon soz dont know where do you find the engine number? their is a hole lot of files and brochers and enginneering drawings i will have a look thew them
The VIN looks wrong though like either it's made up or typed incorrectly. Is this a fair dinkum post?
The VIN looks wrong though like either its made up or typed incorrectly. Is this a fair dinkum post?
Factory V8????
I reckon this could be someone pulling our leg.
Factory V8 LJ Coupe
Uncle was an engineer at Holden.
yes fair dinks i will check numbers agin 2moro
Post your numbers on gmh-torana.com to check if XU1. That is an early VIN so doesnt have the engine code in it. There were no factory LJ V8, the only LJs Holden had with V8s in them were Harrys prototypes and these were either crushed or converted back an |
You only have to be in front at the end of the race. |
Post your numbers on gmh-torana.com to check if XU1. That is an early VIN so doesnt have the engine code in it. There were no factory LJ V8, the only LJs Holden had with V8s in them were Harry's prototypes and these were either crushed or converted back a |
didnt one got smashed up at the testing ground at Lang Lang. it was too front heavy
^ Thats the main problem with a V8 in an LJ, understeers too much, goes like stink though.
james
I think you will find there were a few dealer fitted dodgies floating around too.
quote: Originally posted by Ross
hi bryon soz dont know where do you find the engine number? their is a hole lot of files and |
4/76 HJ monaroGTS |
Hi Ross, Did you get an answer? Which state are you in? I can help you identify its authenticity as factory V8 if it has XW-7 on the tag. Cheers.
