#1 Posted : Tuesday, 27 May 2008 7:05:03 AM(UTC)
hello can anyone help me identify this torana it is from a deceased estate from my uncle who worked at holdens as a enginneer
it is a LJ 2 door factory V8 it has numbers 82911JH991922 XW7 on a plate near the radiator. is it a xu1?
HK1837 Online
#2 Posted : Tuesday, 27 May 2008 7:20:10 AM(UTC)
It is a GTR. Might be an XU-1. What is its engine number?
HK1837 Online
#3 Posted : Tuesday, 27 May 2008 7:20:10 AM(UTC)
It is a GTR. Might be an XU-1. What is it's engine number?
#4 Posted : Tuesday, 27 May 2008 7:25:32 AM(UTC)
hi bryon soz dont know where do you find the engine number? their is a hole lot of files and brochers and enginneering drawings i will have a look thew them
HK1837 Online
#5 Posted : Tuesday, 27 May 2008 7:33:18 AM(UTC)
The VIN looks wrong though like either it's made up or typed incorrectly. Is this a fair dinkum post?
HK1837 Online
#6 Posted : Tuesday, 27 May 2008 7:33:18 AM(UTC)
The VIN looks wrong though like either its made up or typed incorrectly. Is this a fair dinkum post?
Munromad2004 Offline
#7 Posted : Tuesday, 27 May 2008 7:33:34 AM(UTC)
Munromad2004
Factory V8????
I reckon this could be someone pulling our leg.
Factory V8 LJ Coupe
Uncle was an engineer at Holden.
#8 Posted : Tuesday, 27 May 2008 7:41:15 AM(UTC)
yes fair dinks i will check numbers agin 2moro
JBM Offline
#9 Posted : Tuesday, 27 May 2008 4:24:16 PM(UTC)
JBM
Post your numbers on gmh-torana.com to check if XU1. That is an early VIN so doesnt have the engine code in it. There were no factory LJ V8, the only LJs Holden had with V8s in them were Harrys prototypes and these were either crushed or converted back an
JBM Offline
#10 Posted : Tuesday, 27 May 2008 4:24:16 PM(UTC)
JBM
Post your numbers on gmh-torana.com to check if XU1. That is an early VIN so doesnt have the engine code in it. There were no factory LJ V8, the only LJs Holden had with V8s in them were Harry's prototypes and these were either crushed or converted back a
#11 Posted : Tuesday, 27 May 2008 5:20:32 PM(UTC)
didnt one got smashed up at the testing ground at Lang Lang. it was too front heavy
JBM Offline
#12 Posted : Tuesday, 27 May 2008 5:22:14 PM(UTC)
JBM
^ Thats the main problem with a V8 in an LJ, understeers too much, goes like stink though.
james
FastEHHolden Offline
#13 Posted : Wednesday, 28 May 2008 2:38:46 AM(UTC)
FastEHHolden
I think you will find there were a few dealer fitted dodgies floating around too.
RdS Offline
#14 Posted : Wednesday, 28 May 2008 3:41:44 AM(UTC)
RdS
4/76 HJ monaroGTS
#15 Posted : Tuesday, 2 September 2008 1:15:31 AM(UTC)
Hi Ross,
Did you get an answer? Which state are you in?
I can help you identify its authenticity as factory V8 if it has XW-7 on the tag.
Cheers.
Guest (5)
This page was generated in 0.151 seconds.
