tenticles Offline
#1 Posted : Wednesday, 4 June 2008 1:01:41 AM(UTC)
tenticles
how far can i rebore a 308?
it's a 25 F 4 casting no. on the block ( 25/6/74 ? )
it's out to +.040 atm, looks ok but i want to fit a stroker kit and will prolly go to +.060
btw, any idea of the pistons fitted? the markings on the crown are...
RA9081 040
TOP 002 EF
once again, many thanx to everyone
yes sonny, it's an HQ ute
#2 Posted : Wednesday, 4 June 2008 1:09:03 AM(UTC)
There are heaps of 308s out there running at +0.060 but they do seem to get hot - might just be a co-incidence. If you are going to the expense of a stroker I wouldnt use a block already at 40 thou. Id go looking for a standard bore block and build it at
#3 Posted : Wednesday, 4 June 2008 1:09:03 AM(UTC)
There are heaps of 308's out there running at +0.060 but they do seem to get hot - might just be a co-incidence. If you are going to the expense of a stroker I wouldn't use a block already at 40 thou. I'd go looking for a standard bore block and build it
#4 Posted : Wednesday, 4 June 2008 1:54:02 AM(UTC)
when stroking a 308 to say 355 one only needs a mild cam is this so ? cheers
#5 Posted : Wednesday, 4 June 2008 3:32:36 AM(UTC)
Stroking to 350, not 355. 355 is boring AND stroking.
#6 Posted : Wednesday, 4 June 2008 7:38:19 AM(UTC)
my daily work car is up 60,has air and power steer, pulls a tandam, no drama at all
"ALL WE LEAVE IS MEMORIES.."
"ANYONE CAN RESTORE A CAR, BUT IT TAKES BALLS TO CUT ONE...."
#7 Posted : Thursday, 5 June 2008 2:37:10 AM(UTC)
i know that byron but the question still stands cheers
#8 Posted : Thursday, 5 June 2008 3:28:30 AM(UTC)
Depends on the usage, auto/manual etc.
#9 Posted: : Thursday, 5 June 2008 7:22:52 AM(UTC)
hey tenticles,my l34 block was cast on the same day so check the rear webbing for reinforcment, just in case. and if it has, bore it or sleeve it, or sell it for a premium. but dont scrap it. cheers
tenticles Offline
#10 Posted : Thursday, 5 June 2008 2:30:23 PM(UTC)
tenticles
hi chrome
what does the rear webbing reinforcement look like, and does it make it a stronger block?
yes sonny, its an HQ ute
tenticles Offline
#11 Posted : Thursday, 5 June 2008 2:30:23 PM(UTC)
tenticles
hi chrome
#12 Posted : Thursday, 5 June 2008 9:08:24 PM(UTC)
yes tenticles they are slightly stronger,they have extra casting shaped like 2 x's above the back crank journal,where standard blocks are just flat, all blocks after i think 1984 have the reinforced webbing anyway. but with your casting dates and if it ha
#13 Posted : Thursday, 5 June 2008 9:08:24 PM(UTC)
yes tenticles they are slightly stronger,they have extra casting shaped like 2 xs above the back crank journal,where standard blocks are just flat, all blocks after i think 1984 have the reinforced webbing anyway. but with your casting dates and if it has
#14 Posted : Thursday, 5 June 2008 11:12:48 PM(UTC)
Just to expand, from memory they were Repco? designed/modified F5000 blocks and used by Holden for the L34. An NZ prefix is also a good one to have.
If we all had the same (good) taste, who would
tenticles Offline
#15 Posted : Friday, 6 June 2008 12:02:24 AM(UTC)
tenticles
hi chrome, yep, 2 beautiful x's, 1 at about 11 o'clock and 1 at 1 o'clock
tenticles Offline
#16 Posted : Friday, 6 June 2008 12:02:24 AM(UTC)
tenticles
hi chrome, yep, 2 beautiful xs, 1 at about 11 oclock and 1 at 1 oclock
#17 Posted : Friday, 6 June 2008 12:06:47 AM(UTC)
What is the engine number prefix?
#18 Posted : Friday, 6 June 2008 12:33:33 AM(UTC)
sounds good, just need to know engine letters and first 3 numbers. because it could be a vk black block. going off the date castings doesnt tell you which decade. eg 74 or 84 .regardless they are good blocks
tenticles Offline
#19 Posted : Friday, 6 June 2008 3:04:51 AM(UTC)
tenticles
QT 539xxx
but hang on, ive just checked a 253 and a blue block, and they both have that x type bracing
am i looking at the right thing?
Edited by user Friday, 6 June 2008 3:08:14 AM(UTC)  | Reason: Not specified
tenticles Offline
#20 Posted : Friday, 6 June 2008 3:04:51 AM(UTC)
tenticles
QT 539xxx
but hang on, i've just checked a 253 and a blue block, and they both have that x type bracing
Guest (6)
This page was generated in 0.149 seconds.
