how far can i rebore a 308?
it's a 25 F 4 casting no. on the block ( 25/6/74 ? )
it's out to +.040 atm, looks ok but i want to fit a stroker kit and will prolly go to +.060
btw, any idea of the pistons fitted? the markings on the crown are...
RA9081 040 TOP 002 EF
once again, many thanx to everyone
yes sonny, it's an HQ ute |
There are heaps of 308s out there running at +0.060 but they do seem to get hot - might just be a co-incidence. If you are going to the expense of a stroker I wouldnt use a block already at 40 thou. Id go looking for a standard bore block and build it at |
There are heaps of 308's out there running at +0.060 but they do seem to get hot - might just be a co-incidence. If you are going to the expense of a stroker I wouldn't use a block already at 40 thou. I'd go looking for a standard bore block and build it |
when stroking a 308 to say 355 one only needs a mild cam is this so ? cheers
Stroking to 350, not 355. 355 is boring AND stroking.
my daily work car is up 60,has air and power steer, pulls a tandam, no drama at all
"ALL WE LEAVE IS MEMORIES.."
"ANYONE CAN RESTORE A CAR, BUT IT TAKES BALLS TO CUT ONE...."
i know that byron but the question still stands cheers
Depends on the usage, auto/manual etc.
hey tenticles,my l34 block was cast on the same day so check the rear webbing for reinforcment, just in case. and if it has, bore it or sleeve it, or sell it for a premium. but dont scrap it. cheers
hi chrome
what does the rear webbing reinforcement look like, and does it make it a stronger block?
yes sonny, its an HQ ute |
hi chrome
yes tenticles they are slightly stronger,they have extra casting shaped like 2 x's above the back crank journal,where standard blocks are just flat, all blocks after i think 1984 have the reinforced webbing anyway. but with your casting dates and if it ha
yes tenticles they are slightly stronger,they have extra casting shaped like 2 xs above the back crank journal,where standard blocks are just flat, all blocks after i think 1984 have the reinforced webbing anyway. but with your casting dates and if it has
Just to expand, from memory they were Repco? designed/modified F5000 blocks and used by Holden for the L34. An NZ prefix is also a good one to have.
_______________________________________________________ If we all had the same (good) taste, who would |
hi chrome, yep, 2 beautiful x's, 1 at about 11 o'clock and 1 at 1 o'clock
hi chrome, yep, 2 beautiful xs, 1 at about 11 oclock and 1 at 1 oclock
What is the engine number prefix?
sounds good, just need to know engine letters and first 3 numbers. because it could be a vk black block. going off the date castings doesnt tell you which decade. eg 74 or 84 .regardless they are good blocks
QT 539xxx but hang on, ive just checked a 253 and a blue block, and they both have that x type bracing am i looking at the right thing? yes sonny, its an HQ ute Edited by user Friday, 6 June 2008 3:08:14 AM(UTC)
| Reason: Not specified |
QT 539xxx but hang on, i've just checked a 253 and a blue block, and they both have that x type bracing am i looking at the right thing? yes sonny, it's an HQ ute Edited by user Friday, 6 June 2008 3:08:14 AM(UTC)
