jabba Offline
#1 Posted : Tuesday, 17 June 2008 4:51:33 PM(UTC)
jabba
I have just discovered that in the HJ GTS/4 my TH400 gearbox is actually a TH350. (Which is one reason I struggled to find the electrical kickdown connector - there wasn't one).
The rod shifter is adequate for park through drive, but won't select down as far as first, due to the slop in the linkages.
I have acquired the HQ cable shifter mechanism for the TH350/400. The mechanism under console seems quite bulky, and bolts in different places.
Has anyone swapped from rod to cable (either Holden cable or aftermarket)? Are there any tips / tricks / traps to watch for?
j
#2 Posted : Tuesday, 17 June 2008 5:50:02 PM(UTC)
Personally I don't like that cable mechanism. I think they were out of a HZ, possibly Statesman only. Where is the sloppyness? Maybe you just need another T-bar mech?
If we all had the same (good
#3 Posted : Tuesday, 17 June 2008 5:50:02 PM(UTC)
Personally I dont like that cable mechanism. I think they were out of a HZ, possibly Statesman only. Where is the sloppyness? Maybe you just need another T-bar mech?
If we all had the same (good)
jabba Offline
#4 Posted : Tuesday, 17 June 2008 9:47:47 PM(UTC)
jabba
The adjusting mount from the rod to the gearbox selctor slops about a bit. I have played with the number of washers to try and prevent wobble while still permitting shifting and not loosing shaft out hole because bolt not done up(a delicate balance).
#5 Posted : Tuesday, 17 June 2008 10:30:00 PM(UTC)
I've always found them to be pretty tight. See if you can find replacement rod and trunnion (bit that rod slides through on gearbox end) off a trimatic car, and use them on yours. The rubber on the gearbox selector might be flogged out too.
___________
#6 Posted : Tuesday, 17 June 2008 10:30:00 PM(UTC)
Ive always found them to be pretty tight. See if you can find replacement rod and trunnion (bit that rod slides through on gearbox end) off a trimatic car, and use them on yours. The rubber on the gearbox selector might be flogged out too.
____________
HZute-efi-VS5L Offline
#7 Posted : Tuesday, 17 June 2008 10:39:35 PM(UTC)
HZute-efi-VS5L
jabba i would be interested in buying you mechanical t400 shifter and linkage if you dont want it?
jason
www.stickthisdecals.com.au
basketcasebear Offline
#8 Posted : Wednesday, 18 June 2008 6:42:01 AM(UTC)
basketcasebear
hey jabba,
i had the same truble, with my conversion, and found the arm connected to the rod going into the auto, was worn, and loose,, so i tack welded it,
been good since?
just a thought.
bcb
ptpro
some men see things as they are, and as
DOH!!!
#9 Posted : Wednesday, 18 June 2008 6:45:30 AM(UTC)
basketcasebear
oh, also, how does one know whether it is t400 or t350?
is it the shape of the pan,
be funny if i got a 350, and not a 400??
mine came out of a 79 vbsle, euro,
thanks already
bcb
ptpro
some men see things as they are, and ask "why"
I dream of t
DOH!!!
jabba Offline
#10 Posted : Wednesday, 18 June 2008 8:18:14 PM(UTC)
jabba
Shape of pan is a big giveaway. The 350 is a rectangle with one corner cut offf. The 400 has corner cut off and a bit sticking out on the other side. (Google hydramatic gearbox identification, there are a couple of sites which show differences.
Also,
klompy Offline
#11 Posted : Thursday, 19 June 2008 3:35:47 AM(UTC)
klompy
I used a cable on my column change HQ to a turbo 350,just couldnt get those mechanical rods sorted.Was much easier and works a treat.
klompy Offline
#12 Posted : Thursday, 19 June 2008 3:35:47 AM(UTC)
klompy
I used a cable on my column change HQ to a turbo 350,just could'nt get those mechanical rods sorted.Was much easier and works a treat.
jabba Offline
#13 Posted : Thursday, 19 June 2008 3:15:19 PM(UTC)
jabba
If you are after mechanical linkages, trademe has some up for sale at the moment. I am just waiting for new bracket to arrive to nail cable to gearbox and will try the switch over.
Now have first gear 2 out of three times. There is still around 1/2 inc
jabba Offline
#14 Posted : Sunday, 1 February 2009 3:28:38 PM(UTC)
jabba
During engine out rebuild, I removed the rod mechanism and fitted old school B&M hammer cable shifter. much tighter and better. Looking at rod version that came out it is really straightforward. Only two connectors and, yes, both were flogged.
Jason,
This page was generated in 0.110 seconds.
