jabba Offline
#1 Posted : Tuesday, 17 June 2008 4:51:33 PM(UTC)
jabba
I have just discovered that in the HJ GTS/4 my TH400 gearbox is actually a TH350. (Which is one reason I struggled to find the electrical kickdown connector - there wasn't one).
The rod shifter is adequate for park through drive, but won't select down as far as first, due to the slop in the linkages.
I have acquired the HQ cable shifter mechanism for the TH350/400. The mechanism under console seems quite bulky, and bolts in different places.
Has anyone swapped from rod to cable (either Holden cable or aftermarket)? Are there any tips / tricks / traps to watch for?
j
#2 Posted : Tuesday, 17 June 2008 5:50:02 PM(UTC)
Personally I don't like that cable mechanism. I think they were out of a HZ, possibly Statesman only. Where is the sloppyness? Maybe you just need another T-bar mech?
If we all had the same (good
#3 Posted : Tuesday, 17 June 2008 5:50:02 PM(UTC)
Personally I dont like that cable mechanism. I think they were out of a HZ, possibly Statesman only. Where is the sloppyness? Maybe you just need another T-bar mech?
If we all had the same (good)
jabba Offline
#4 Posted : Tuesday, 17 June 2008 9:47:47 PM(UTC)
jabba
The adjusting mount from the rod to the gearbox selctor slops about a bit. I have played with the number of washers to try and prevent wobble while still permitting shifting and not loosing shaft out hole because bolt not done up(a delicate balance).
#5 Posted : Tuesday, 17 June 2008 10:30:00 PM(UTC)
I've always found them to be pretty tight. See if you can find replacement rod and trunnion (bit that rod slides through on gearbox end) off a trimatic car, and use them on yours. The rubber on the gearbox selector might be flogged out too.
___________
#6 Posted : Tuesday, 17 June 2008 10:30:00 PM(UTC)
Ive always found them to be pretty tight. See if you can find replacement rod and trunnion (bit that rod slides through on gearbox end) off a trimatic car, and use them on yours. The rubber on the gearbox selector might be flogged out too.
____________
HZute-efi-VS5L Offline
#7 Posted : Tuesday, 17 June 2008 10:39:35 PM(UTC)
HZute-efi-VS5L
jabba i would be interested in buying you mechanical t400 shifter and linkage if you dont want it?
jason
www.stickthisdecals.com.au
basketcasebear Offline
#8 Posted : Wednesday, 18 June 2008 6:42:01 AM(UTC)
basketcasebear
hey jabba,
i had the same truble, with my conversion, and found the arm connected to the rod going into the auto, was worn, and loose,, so i tack welded it,
been good since?
just a thought.
bcb
ptpro
some men see things as they are, and as
DOH!!!
#9 Posted : Wednesday, 18 June 2008 6:45:30 AM(UTC)
basketcasebear
oh, also, how does one know whether it is t400 or t350?
is it the shape of the pan,
be funny if i got a 350, and not a 400??
mine came out of a 79 vbsle, euro,
thanks already
bcb
ptpro
some men see things as they are, and ask "why"
I dream of t
DOH!!!
jabba Offline
#10 Posted : Wednesday, 18 June 2008 8:18:14 PM(UTC)
jabba
Shape of pan is a big giveaway. The 350 is a rectangle with one corner cut offf. The 400 has corner cut off and a bit sticking out on the other side. (Google hydramatic gearbox identification, there are a couple of sites which show differences.
Also,
klompy Offline
#11 Posted : Thursday, 19 June 2008 3:35:47 AM(UTC)
klompy
I used a cable on my column change HQ to a turbo 350,just couldnt get those mechanical rods sorted.Was much easier and works a treat.
klompy Offline
#12 Posted : Thursday, 19 June 2008 3:35:47 AM(UTC)
klompy
I used a cable on my column change HQ to a turbo 350,just could'nt get those mechanical rods sorted.Was much easier and works a treat.
jabba Offline
#13 Posted : Thursday, 19 June 2008 3:15:19 PM(UTC)
jabba
If you are after mechanical linkages, trademe has some up for sale at the moment. I am just waiting for new bracket to arrive to nail cable to gearbox and will try the switch over.
Now have first gear 2 out of three times. There is still around 1/2 inc
jabba Offline
#14 Posted : Sunday, 1 February 2009 3:28:38 PM(UTC)
jabba
During engine out rebuild, I removed the rod mechanism and fitted old school B&M hammer cable shifter. much tighter and better. Looking at rod version that came out it is really straightforward. Only two connectors and, yes, both were flogged.
Jason,
Guest (6)
