HotRodder Offline
#1 Posted : Sunday, 22 June 2008 7:24:15 AM(UTC)
HotRodder
I have a 253 Holden engine and the camshaft and crankshaft has a some surface rust on the parts that the bearing goes on, can I just get some emery paper and remove the rusty bits or would I need to take them to an engine place.If I do need to have some work done would I need to take the block along to.
#2 Posted : Sunday, 22 June 2008 9:43:40 PM(UTC)
Take it to a machine shop and get them to linish it, and then measure it up. It may be fine.
HotRodder Offline
#3 Posted : Sunday, 22 June 2008 10:03:25 PM(UTC)
HotRodder
Thanks I'll look up that linish word on utube to see whats done.
Whats the worst that could happen if I just use the emery paper to remove it.
HotRodder Offline
#4 Posted : Sunday, 22 June 2008 10:03:25 PM(UTC)
HotRodder
Thanks Ill look up that linish word on utube to see whats done.
antoni Offline
#5 Posted : Monday, 23 June 2008 8:25:06 AM(UTC)
antoni
Hi ues 400 wet / dry wet with keo, do it right and grid it to bring back like new.
HotRodder Offline
#6 Posted : Monday, 23 June 2008 10:07:54 AM(UTC)
HotRodder
Hi Antoni, I'll give the 400 wet&dry with kero a go first then get the new bearings to suit.
HotRodder Offline
#7 Posted : Monday, 23 June 2008 10:07:54 AM(UTC)
HotRodder
Hi Antoni, Ill give the 400 wet&dry with kero a go first then get the new bearings to suit.
