bundybluedog Offline
#1 Posted : Saturday, 12 July 2008 4:10:48 AM(UTC)
bundybluedog
When fitting a VP SS engine to a HX can you run any turbo pattern tranny/gearbox like the VN V8 engine or will there be ECU problems?
Dan
#2 Posted : Saturday, 12 July 2008 5:37:24 AM(UTC)
VN and VP engines are basically the same, so you can run any box you want. Just need the in-line speed sensor from Kalmaker that outputs 2 pulses per rev for the ECU and cruise control. When you get the engine make sure you get the cruise control bits as
#3 Posted : Saturday, 12 July 2008 5:49:03 AM(UTC)
Yeah, VN & VP are fine.
Its VR onwards autos that suffer the ECU issues with gearbox swaps.
A lot of people aim to achieve nothing in life - and have amazing accurac
#4 Posted : Saturday, 12 July 2008 5:49:03 AM(UTC)
It's VR onwards autos that suffer the ECU issues with gearbox swaps.
#5 Posted : Saturday, 12 July 2008 7:45:45 PM(UTC)
bundybluedog
Thanks guys
mmazz30 Offline
#6 Posted : Saturday, 12 July 2008 10:05:13 PM(UTC)
mmazz30
I've never taken notice of what the WB-VK cruise stalk/switches looked like.
I'm in the middle of fitting the VN cruise module,VS module cable(shorter)
and brake switches,but thinking what stalk/switch to use?
I fitted the HZ column and stalk to my HJ
mmazz30 Offline
#7 Posted : Saturday, 12 July 2008 10:05:13 PM(UTC)
mmazz30
Ive never taken notice of what the WB-VK cruise stalk/switches looked like.
Im in the middle of fitting the VN cruise module,VS module cable(shorter)
I fitted the HZ column and stalk to my HJ co
#8 Posted : Saturday, 12 July 2008 10:10:46 PM(UTC)
There is no cruise stalk on a WB. Just a button on the pot. They do fit straight on.
If you look at the schematics for VN-VP cruise it's just buttons ie activate, up & down. SO if you use the WB activate switch you just need two more buttons on the dash
Edited by user Saturday, 12 July 2008 10:13:08 PM(UTC)  | Reason: Not specified
#9 Posted : Saturday, 12 July 2008 10:10:46 PM(UTC)
If you look at the schematics for VN-VP cruise its just buttons ie activate, up & down. SO if you use the WB activate switch you just need two more buttons on the dash f
#10 Posted : Saturday, 12 July 2008 10:38:11 PM(UTC)
The VC/VH/VK/WB cruise switch is no good with VN cruise.
I'm actually going through this at the moment with a VN 5L/T5 into a VB.
VN cruise needs on/off (latching action) as well as the +/- (momentary action) buttons.
VR onwards achieve a latching
#11 Posted : Saturday, 12 July 2008 10:38:11 PM(UTC)
Im actually going through this at the moment with a VN 5L/T5 into a VB.
VR onwards achieve a latching a
mmazz30 Offline
#12 Posted : Sunday, 13 July 2008 2:15:47 AM(UTC)
mmazz30
Byron,thats why i never noticed a cruise stalk on WB...lol
Mick i originally thought about VS/VT type as well but like you said it needs an ON/OFF switch as the BCM does the switching.
Had a look today at the wreckers and a few of the jap cars had a s
#13 Posted : Sunday, 13 July 2008 7:20:51 PM(UTC)
Why don't you use the factory HJ headlight dipper switch on the floor for the latching on/off switch and Magna paddle for the up/down?
If we all had the same (good) taste, who would buy all the F
#14 Posted : Sunday, 13 July 2008 7:20:51 PM(UTC)
Why dont you use the factory HJ headlight dipper switch on the floor for the latching on/off switch and Magna paddle for the up/down?
If we all had the same (good) taste, who would buy all the Fo
mmazz30 Offline
#15 Posted : Monday, 14 July 2008 6:02:04 AM(UTC)
mmazz30
Good thinking Byron!
I originally used the dipper to activate my TCC pre EFI....so its sits lonely and unloved at the moment.
cheers...mario
