When fitting a VP SS engine to a HX can you run any turbo pattern tranny/gearbox like the VN V8 engine or will there be ECU problems? Dan |
Havent you learnt anything from that guy that gives sermons at church?...Captain whats his name. |
VN and VP engines are basically the same, so you can run any box you want. Just need the in-line speed sensor from Kalmaker that outputs 2 pulses per rev for the ECU and cruise control. When you get the engine make sure you get the cruise control bits as |
Yeah, VN & VP are fine.
Its VR onwards autos that suffer the ECU issues with gearbox swaps.
A lot of people aim to achieve nothing in life - and have amazing accurac |
It's VR onwards autos that suffer the ECU issues with gearbox swaps.
A lot of people aim to achieve nothing in life - and have amazing accura |
I've never taken notice of what the WB-VK cruise stalk/switches looked like. I'm in the middle of fitting the VN cruise module,VS module cable(shorter) and brake switches,but thinking what stalk/switch to use? I fitted the HZ column and stalk to my HJ
Ive never taken notice of what the WB-VK cruise stalk/switches looked like. Im in the middle of fitting the VN cruise module,VS module cable(shorter) and brake switches,but thinking what stalk/switch to use? I fitted the HZ column and stalk to my HJ co
There is no cruise stalk on a WB. Just a button on the pot. They do fit straight on. If you look at the schematics for VN-VP cruise it's just buttons ie activate, up & down. SO if you use the WB activate switch you just need two more buttons on the dash Edited by user Saturday, 12 July 2008 10:13:08 PM(UTC)
| Reason: Not specified |
There is no cruise stalk on a WB. Just a button on the pot. They do fit straight on. If you look at the schematics for VN-VP cruise its just buttons ie activate, up & down. SO if you use the WB activate switch you just need two more buttons on the dash f Edited by user Saturday, 12 July 2008 10:13:08 PM(UTC)
The VC/VH/VK/WB cruise switch is no good with VN cruise. I'm actually going through this at the moment with a VN 5L/T5 into a VB.
VN cruise needs on/off (latching action) as well as the +/- (momentary action) buttons.
VR onwards achieve a latching |
The VC/VH/VK/WB cruise switch is no good with VN cruise. Im actually going through this at the moment with a VN 5L/T5 into a VB.
VR onwards achieve a latching a |
Byron,thats why i never noticed a cruise stalk on WB...lol
Mick i originally thought about VS/VT type as well but like you said it needs an ON/OFF switch as the BCM does the switching. Had a look today at the wreckers and a few of the jap cars had a s
Why don't you use the factory HJ headlight dipper switch on the floor for the latching on/off switch and Magna paddle for the up/down?
_______________________________________________________ If we all had the same (good) taste, who would buy all the F |
Why dont you use the factory HJ headlight dipper switch on the floor for the latching on/off switch and Magna paddle for the up/down?
_______________________________________________________ If we all had the same (good) taste, who would buy all the Fo |
Good thinking Byron! I originally used the dipper to activate my TCC pre EFI....so its sits lonely and unloved at the moment.
cheers...mario
