#1 Posted : Thursday, 11 September 2008 7:38:19 AM(UTC)
Hi all, wonder if anyone could give me some information on the idea of changing out a gen 81 WB 1 tonner diff with something around 2.78 to give me better milage up the highway. I have done some research on earlier model holdens that have run 2.78 ratios, which of these would I be able to bolt straight in. I currently running a 4 speed manual M21 with the 4.2 up front.
Any info on this matter would be great.
thanks
crowe Offline
#2 Posted : Thursday, 11 September 2008 8:44:19 AM(UTC)
crowe
Been there done that 253/M21/3.08 diff stay with that combo. The 253 needs some RPM to run, its not a torquey motor and the aero dynamics is not good. did what you want to a HZ Sdn and could only pull 170kph in top gear and that was about 3500 rpm. it jus
crowe Offline
#3 Posted : Thursday, 11 September 2008 8:44:19 AM(UTC)
crowe
Been there done that 253/M21/3.08 diff stay with that combo. The 253 needs some RPM to run, its not a torque'y motor and the aero dynamics is not good. did what you want to a HZ Sdn and could only pull 170kph in top gear and that was about 3500 rpm. it ju
#4 Posted : Thursday, 11 September 2008 11:31:03 AM(UTC)
no good, stay with 3.08 or even go to 3.36
AFTER 1972 THERE AINT NO MUSCLE CARS AND MATCHING NUMBERS ARE FOR TIMES TABLES....
XY GTHO PH111 , now thats muscle...
#5 Posted : Thursday, 11 September 2008 5:59:50 PM(UTC)
Agree. It'd be bad enough in first or reverse with a load as it is!
#6 Posted : Thursday, 11 September 2008 5:59:50 PM(UTC)
Agree. Itd be bad enough in first or reverse with a load as it is!
special-k Offline
#7 Posted : Saturday, 13 September 2008 1:07:32 AM(UTC)
special-k
From personal experience I would probably leave the diff as it is and spend the money on either a Celica or Supra 5spd box.This way you will get good economy a decent spread of ratios and wont lose to much of your low down grunt.
#8 Posted : Thursday, 18 September 2008 12:33:07 AM(UTC)
Thanks for your help, I will leave her as is.
