Hi all, wonder if anyone could give me some information on the idea of changing out a gen 81 WB 1 tonner diff with something around 2.78 to give me better milage up the highway. I have done some research on earlier model holdens that have run 2.78 ratios, which of these would I be able to bolt straight in. I currently running a 4 speed manual M21 with the 4.2 up front. Any info on this matter would be great. thanks
Joined: 3/03/2005(UTC) Posts: 287 ![Australia Australia]()
Been there done that 253/M21/3.08 diff stay with that combo. The 253 needs some RPM to run, its not a torquey motor and the aero dynamics is not good. did what you want to a HZ Sdn and could only pull 170kph in top gear and that was about 3500 rpm. it jus
Been there done that 253/M21/3.08 diff stay with that combo. The 253 needs some RPM to run, its not a torque'y motor and the aero dynamics is not good. did what you want to a HZ Sdn and could only pull 170kph in top gear and that was about 3500 rpm. it ju
no good, stay with 3.08 or even go to 3.36
AFTER 1972 THERE AINT NO MUSCLE CARS AND MATCHING NUMBERS ARE FOR TIMES TABLES....
XY GTHO PH111 , now thats muscle...
Agree. It'd be bad enough in first or reverse with a load as it is!
Agree. Itd be bad enough in first or reverse with a load as it is!
From personal experience I would probably leave the diff as it is and spend the money on either a Celica or Supra 5spd box.This way you will get good economy a decent spread of ratios and wont lose to much of your low down grunt.
Thanks for your help, I will leave her as is.
