jimpram Offline
#1 Posted : Saturday, 11 October 2008 12:57:02 AM(UTC)
jimpram
How can you tell if a 350 sbc is 4 bolt main without having to take sump off? I have been told in the past that if the engine No. finishes in (010) that it is a 4 bolt main. Is this true?
Tis he who asks that finds out................
Edited by user Saturday, 11 October 2008 1:30:48 AM(UTC)  | Reason: Not specified
#2 Posted : Saturday, 11 October 2008 2:17:01 AM(UTC)
untrue. they came in 2 or 4 bolt main, i have a 2 blt 010 high nickel block. cheers.
jimpram Offline
#3 Posted : Saturday, 11 October 2008 3:07:37 AM(UTC)
jimpram
So what does 010 mean when someone says its an 010 block?
PISTOF Offline
#4 Posted : Saturday, 11 October 2008 4:41:10 AM(UTC)
PISTOF
010 (or 020) blocks have an additional 1% tin and 2% nickel added to the cast iron. You hear 010 4 bolt a lot as they are the stronger more desirable blocks. 010 or 020 will be stamped under the timing chain cover or on the back top ledge, it is not part
jimpram Offline
#5 Posted : Saturday, 11 October 2008 6:10:04 AM(UTC)
jimpram
Thanks for your help PISTOF.
But what should that raised number be to determine 2 or 4 bolt?
Will it say 4 bolt or 2 bolt or special number sequence?
Edited by user Saturday, 11 October 2008 7:06:29 AM(UTC)  | Reason: Not specified
PISTOF Offline
#6 Posted : Saturday, 11 October 2008 7:32:14 AM(UTC)
PISTOF
It varies heaps mate, youll have to look the number up.
Have a look here and youll see what i mean.. http://www.mortec.com/castnum.htm
PISTOF Offline
#7 Posted : Saturday, 11 October 2008 7:32:14 AM(UTC)
PISTOF
It varies heaps mate, you'll have to look the number up.
Have a look here and you'll see what i mean.. http://www.mortec.com/castnum.htm
This page was generated in 0.083 seconds.
