78XC Offline
#1 Posted: : Monday, 15 December 2008 3:32:23 AM(UTC)
78XC
Hi I've got an XC sedan with 9 inch disc's rear end and I don't know what the most offset or size of wheels I can fit not sure what the standard offset is I want to try and fit 15x10's if possibble anyone that can help I would really appreciate it thanks.
snappa Offline
#2 Posted : Monday, 15 December 2008 5:57:06 AM(UTC)
snappa
5 inch back space I think
351 ZH
351 ZH
78XC Offline
#3 Posted : Tuesday, 16 December 2008 3:11:48 AM(UTC)
78XC
I just tried a 4 inch backspace on a 10 inch rim and 295 tyre and it does not fit.
Tex Scrotum rides again Offline
#4 Posted : Tuesday, 16 December 2008 3:32:23 AM(UTC)
I doubt you'll get a 295 under the guards,but maybe a 265 on a 10(but 9 would be better)and the 265s look good on a 10inch rim.
Try a 6inch backspace(6inchs in from flange,4inchs out from flange) with a 265,I reckon that will come close to fitting!!!
78XC Offline
#5 Posted : Wednesday, 17 December 2008 5:36:41 AM(UTC)
78XC
I just took the wheel off and did some measurements and at this point in time it looks like it could fit a 10 inch rim with 4.5 inch backset and whilst lowered the wheel fits into the arch and leaves about an inch from the leaf springs "theoretically"
#6 Posted : Thursday, 18 December 2008 12:42:19 AM(UTC)
You could make up a little jig out of some scrap timber to measure exactly what can fit under your guards.
Get a peice of wood approx 100mm X 20mm(old fence paling) and cut it about 20mm less than the tyre diameter,then drill some holes in it so you ca
78XC Offline
#7 Posted : Thursday, 18 December 2008 1:33:50 AM(UTC)
78XC
mate that is a great idea I was thinking of getting an old ford rim and grinding it out and making some sort of adjustable thing, but thats great I'll do that I can even make the total diameter of the wheel size and that way i can see how high the car wil
XB351 Offline
#8 Posted : Friday, 19 December 2008 7:18:03 AM(UTC)
XB351
The biggest tyre you'll fit under the guards is 28" tall and 10" wide. That's using stock offset rims ie XB-EL. 10" wide is around a 275 wide tyre.
Note: It could be 10.5" wide? I don't have easy enough access to go and read the sidewall of my tyres.
Edited by user Friday, 19 December 2008 7:20:05 AM(UTC)  | Reason: Not specified
78XC Offline
#9 Posted : Friday, 19 December 2008 7:55:51 AM(UTC)
78XC
thanks for that I estimated that I have 720mm in height as I put a plumb bob down from the inside of my guard and thats with a 1.5inch lowering block so you telling me that helps thankyou, I'm pretty sure the 10 will fit with like you said 275 tyre so I'm
Guest (10)
