78XC Offline
#1 Posted : Monday, 15 December 2008 3:32:23 AM(UTC)
78XC
Hi I've got an XC sedan with 9 inch disc's rear end and I don't know what the most offset or size of wheels I can fit not sure what the standard offset is I want to try and fit 15x10's if possibble anyone that can help I would really appreciate it thanks.
snappa Offline
#2 Posted : Monday, 15 December 2008 5:57:06 AM(UTC)
snappa
5 inch back space I think
351 ZH
351 ZH
78XC Offline
#3 Posted : Tuesday, 16 December 2008 3:11:48 AM(UTC)
78XC
I just tried a 4 inch backspace on a 10 inch rim and 295 tyre and it does not fit.
Tex Scrotum rides again Offline
#4 Posted : Tuesday, 16 December 2008 3:32:23 AM(UTC)
I doubt you'll get a 295 under the guards,but maybe a 265 on a 10(but 9 would be better)and the 265s look good on a 10inch rim.
Try a 6inch backspace(6inchs in from flange,4inchs out from flange) with a 265,I reckon that will come close to fitting!!!
78XC Offline
#5 Posted : Wednesday, 17 December 2008 5:36:41 AM(UTC)
78XC
I just took the wheel off and did some measurements and at this point in time it looks like it could fit a 10 inch rim with 4.5 inch backset and whilst lowered the wheel fits into the arch and leaves about an inch from the leaf springs "theoretically"
#6 Posted : Thursday, 18 December 2008 12:42:19 AM(UTC)
You could make up a little jig out of some scrap timber to measure exactly what can fit under your guards.
Get a peice of wood approx 100mm X 20mm(old fence paling) and cut it about 20mm less than the tyre diameter,then drill some holes in it so you ca
78XC Offline
#7 Posted : Thursday, 18 December 2008 1:33:50 AM(UTC)
78XC
mate that is a great idea I was thinking of getting an old ford rim and grinding it out and making some sort of adjustable thing, but thats great I'll do that I can even make the total diameter of the wheel size and that way i can see how high the car wil
XB351 Offline
#8 Posted : Friday, 19 December 2008 7:18:03 AM(UTC)
XB351
The biggest tyre you'll fit under the guards is 28" tall and 10" wide. That's using stock offset rims ie XB-EL. 10" wide is around a 275 wide tyre.
Note: It could be 10.5" wide? I don't have easy enough access to go and read the sidewall of my tyres.
Edited by user Friday, 19 December 2008 7:20:05 AM(UTC)  | Reason: Not specified
78XC Offline
#9 Posted : Friday, 19 December 2008 7:55:51 AM(UTC)
78XC
thanks for that I estimated that I have 720mm in height as I put a plumb bob down from the inside of my guard and thats with a 1.5inch lowering block so you telling me that helps thankyou, I'm pretty sure the 10 will fit with like you said 275 tyre so I'm
This page was generated in 0.082 seconds.
