Can anybody tell me if there is a difference between 6cyl and 8cyl radiator support panels on the HG,HK and HT models.
John
no difference in panels, but the 6 uses a "spacer" which looks like a box
No. HK is different for the grille mounts. And Premier/Brougham is different of course.
Sorry for the confusion, what i mean is, is the rad support panel for the 8cyl of a stronger construction than the 6cyl, regardless of model, grills etc. As is the case with the XA to XC Fords, the rad support panel is reinforced and the opening for the r
That is what I answered. No, they are the same.
The answer is Holden engineered their cars to take all engines, so no difference in:
Crossmember Front chassis Radiator support
If you look at front chassis, there are two types per model, single and dual headlight.
HK and HT are different to e
Warren, the one across the front top as you refer to it, whats the difference in the 2 HK versions ?..... Jack.
Greedy barstard,you dont need to coupes lol
toptrix
