XB351COUPE Offline
#1 Posted : Saturday, 24 January 2009 11:56:19 PM(UTC)
XB351COUPE
Can anybody tell me if there is a difference between 6cyl and 8cyl radiator support panels on the HG,HK and HT models.
John
#2 Posted : Sunday, 25 January 2009 12:01:44 AM(UTC)
no difference in panels, but the 6 uses a "spacer" which looks like a box
#3 Posted : Sunday, 25 January 2009 2:49:57 AM(UTC)
No. HK is different for the grille mounts. And Premier/Brougham is different of course.
XB351COUPE Offline
#4 Posted : Sunday, 25 January 2009 3:21:59 AM(UTC)
XB351COUPE
Sorry for the confusion, what i mean is, is the rad support panel for the 8cyl of a stronger construction than the 6cyl, regardless of model, grills etc. As is the case with the XA to XC Fords, the rad support panel is reinforced and the opening for the r
#5 Posted : Sunday, 25 January 2009 6:58:01 PM(UTC)
That is what I answered. No, they are the same.
#6 Posted : Sunday, 25 January 2009 9:05:24 PM(UTC)
The answer is Holden engineered their cars to take all engines, so no difference in:
Crossmember
Front chassis
Radiator support
If you look at front chassis, there are two types per model, single and dual headlight.
HK and HT are different to e
blameyone Offline
#7 Posted : Monday, 26 January 2009 12:45:01 AM(UTC)
blameyone
Warren, the one across the front top as you refer to it, whats the difference in the 2 HK versions ?..... Jack.
XB351COUPE Offline
#8 Posted : Tuesday, 27 January 2009 5:13:54 AM(UTC)
XB351COUPE
lxtoranahzute Offline
#9 Posted : Tuesday, 3 February 2009 9:26:15 AM(UTC)
lxtoranahzute
Greedy barstard,you dont need to coupes lol
toptrix
