oHQo Offline
#1 Posted : Saturday, 14 February 2009 1:06:27 AM(UTC)
oHQo
Can anyone here decode this for me please? 1705 6280. 3016. I need a cheap carby urgent and found this, but I need to know what its off cause it's going on my standard 253.
Scott
#2 Posted : Saturday, 14 February 2009 3:41:01 AM(UTC)
Possibly 1705 = 1976 to 1979, 6 = 1976 , 2 = 4 bbl quady ,8 = GM , 0 = manual trans. Some one correct me if Im wrong.
#3 Posted : Saturday, 14 February 2009 3:43:39 AM(UTC)
Also 3016 is a date code,possibly 1/3/76
#4 Posted : Saturday, 14 February 2009 6:52:17 AM(UTC)
Its an LX Torana 308 Auto Or manual Full Pollution Carby . Most Quadrajets are different from Manual to Auto but these ones were numbered the same . Just that manual cars get a vacuum outlet blocked off coming out at the right front . 3016 means the 301st
oHQo Offline
#5 Posted : Saturday, 14 February 2009 7:27:26 AM(UTC)
oHQo
Thanks mate, that helps me alot. Sounds like you know your stuff. What is a recoed one of these worth?
Scott
#6 Posted : Saturday, 14 February 2009 7:40:16 AM(UTC)
About $450 outright. Email me and i will let you know a place to get a good quality one from . [email protected]
There is a crowd on ebay you can buy them for $220 outright and you can probably buy cheaper ones , but i promise you that you get wh
oHQo Offline
#7 Posted : Saturday, 14 February 2009 8:52:49 AM(UTC)
oHQo
How does 601, 602, 603 come into play? Is it cast on the carby somewhere? How can you tell what it is just by looking at it? Checked out your site, looks good... only if I had more money I could actually buy something off you. HA HA... With out getting yo
#8 Posted : Saturday, 14 February 2009 9:22:51 AM(UTC)
I would rather not comment, but if i can put it simply it is the quality of peoples workmanship that varies .
Check my new website for plenty of Monaro parts and more to come .
www.monaromuscleparts.com
#9 Posted : Saturday, 14 February 2009 5:11:21 PM(UTC)
601, 602 & 603 are not Rochester numbers. These are part of the Fuel Miser part number system which groups these carbies into 3 lots for the purposes of kit commonality.
As James says, you get what you pay for, that should cover it.
oHQo Offline
#10 Posted : Saturday, 14 February 2009 8:31:23 PM(UTC)
oHQo
Great info guys, thanks for your help.
Scott
#11 Posted : Monday, 16 February 2009 7:28:54 AM(UTC)
I was talking to someone about IDing Q jets today and from my parts books I have got this information.
HQ parts book
308 manual - 7041851 pre ADR 27
308 manual - 17050641 post ADR 27
308 auto - 7041852 pre ADR 27
308 auto - 17050642 post
#12 Posted : Monday, 16 February 2009 8:25:37 AM(UTC)
Are you staking me? or am I stalking you? HA HA. Once again top work on the info. I replied on other site. Thanks for the info.
Scott
JBM Offline
#13 Posted : Monday, 16 February 2009 11:05:33 PM(UTC)
JBM
I have a Quaddy that doesnt match either, it has 7041281 ZE and the first "1" is upside down? The cast date is 0123, so 12 Jan 73?
James
oHQo Offline
#14 Posted : Tuesday, 17 February 2009 1:50:08 AM(UTC)
oHQo
Im a bit unsure of the so called build dates, Found one with 3016 and one with 0783.
#15 Posted : Tuesday, 17 February 2009 10:30:04 AM(UTC)
Hi Scott.
Not stalking you just looking for some answers about this myself.
3016 means 301st day in the 6th year. you need the main number to see which decade.
James if I id this correctly your carby 7041281 is a manual version of my 7041282 auto carb
JBM Offline
#16 Posted : Tuesday, 17 February 2009 9:11:47 PM(UTC)
JBM
Thanks for that break down. Just to comment further, what does the ZF or ZE mean?
James
#17 Posted : Wednesday, 18 February 2009 5:00:49 AM(UTC)
ZA ZB ZC ZD ZE etc are the matching Build sheet numbers whioch are an application code for the assembly line . Like if you see horns or a wiper motor or other parts of your car with a white and black 2 suffix picking code tag . This is the same and will m
Edited by user Wednesday, 18 February 2009 9:51:08 AM(UTC)  | Reason: Not specified
JBM Offline
#18 Posted : Wednesday, 18 February 2009 9:35:48 AM(UTC)
JBM
#19 Posted : Wednesday, 18 February 2009 9:43:11 AM(UTC)
So if ZE is a HQ 308 manual would ZF be a HQ 308 auto carby.
Cheers Paul.
#20 Posted : Wednesday, 18 February 2009 9:50:28 AM(UTC)
Yes sir ZF is HQ 308 Auto, and something many dont realise is that they produced the 7041281 and 7041282 until mid 1973 if you check all the date codes , and then the 7043283 and 7043284 to over after that . So you actually got a 1971 spec carby still in
Edited by user Wednesday, 18 February 2009 9:51:58 AM(UTC)  | Reason: Not specified
