knute Offline
#1 Posted : Wednesday, 18 February 2009 5:41:13 PM(UTC)
knute
my hq is getting a little heavy to steer with the larger tyres
i want to convert it to power steer operation
i have the pump, box, brackets and spacers from an hz station wagon which i wrecked
the heads have been changed to "B" cast
is this a straight bolt on or do i need to add/change other items such as drag links, pitman arms etc
thanx in advance, johnny
knute Offline
#2 Posted : Wednesday, 18 February 2009 6:01:50 PM(UTC)
knute
and ive also got the double belt bottom pulley
Rhys Offline
#3 Posted : Wednesday, 18 February 2009 9:53:47 PM(UTC)
Rhys
Hi Andrew,
Everything you have will bolt straight on. Does the box still have the pitman arm attached? If it doesnt you will either have to find another one to fit to it or remove the one off your manual steering box. They are a bugger to get off unless
#4 Posted : Wednesday, 18 February 2009 10:26:28 PM(UTC)
If its an HQ or an HJ built before Feb 76 it will already have the short steering arms.
The pitman arm off the manual box has a different diameter & spline, so it will not fit. You need the correct power steering pitman arm.
Rhys, be careful telling
Edited by user Thursday, 19 February 2009 2:00:35 AM(UTC)  | Reason: Not specified
Rhys Offline
#5 Posted : Wednesday, 18 February 2009 11:00:59 PM(UTC)
Rhys
Sorry guys, didnt mean to mislead. I was speaking of my experiences in doing a once off conversion.
Dr Terry, when did the metric threads and different hoses come in? What mistakes do a lot of people make when doing this conversion?
Edited by user Wednesday, 18 February 2009 11:02:08 PM(UTC)  | Reason: Not specified
#6 Posted : Thursday, 19 February 2009 2:45:38 AM(UTC)
knute Offline
#7 Posted : Thursday, 19 February 2009 7:15:58 AM(UTC)
knute
thanks guys
just to clarify, the pitman arm is still on the power steer HZ box
so i can just fit it in as an assembly to the HQ draglink ?
74HJLS Offline
#8 Posted : Thursday, 19 February 2009 3:51:11 PM(UTC)
74HJLS
It will fit, I have just done the same thing to my HJ. It should not even efect your front end alignment. make sure you have the steering shaft flexible coupling with it as it is different to the manual one.
Pete.
Old Holdens never die, they
Edited by user Thursday, 19 February 2009 3:53:32 PM(UTC)  | Reason: Not specified
Pete.
knute Offline
#9 Posted : Thursday, 19 February 2009 4:30:31 PM(UTC)
knute
thanks pete
i have a feeling i may not have saved the coupling
how different are they mate ?
74HJLS Offline
#10 Posted : Friday, 20 February 2009 3:07:56 AM(UTC)
74HJLS
The power steering box has a thicker input shaft.
Pete.
Pete.
knute Offline
#11 Posted : Friday, 20 February 2009 6:49:40 AM(UTC)
knute
wahoooooooooooooo
coupling is still on box
